el_cuc0 Posted April 20, 2008 Report Posted April 20, 2008 Hello everybody, i have built my first midi controller using the kit from smash tv. The intention for this device is to control Traktor Studio 3. So I bought the kit and didn't use all of the components because: A) I don't need an LCD Screen. B) I don't need incoming signal. In other words I do not intend to send midi instructions to my device.C) I didn't use C5 or C6 (capacitors connected to J1) because I am supplying power from my computer's USB port. I have put together an AIN Kit too and have only connected 4 pots to it just to get give it a simple test. I am providing power from usb, have all of the unused inputs connected to ground of the cable. I connect the MIDI cable, fire up midimon which is a terminal software on mac os x, and the log says that it resets every so often. I'm not getting a real CC message. I'm not sure what to do at this point, I have connected my multimeter to Tx and am getting a strong 5V signal. Have tested all the points and have even verifired outgoing signal from the AIN to the inputs of the core. I throw my hands up in despair. Please help. Quote
cimo Posted April 20, 2008 Report Posted April 20, 2008 himy first htought is that since you are powering from USB and using AINs then it may be possible that the supply is unstable causing the PIC to crashdo this:1)unplug the supply to the pots or just disconnect the AIN2)try to supply with a stable 5 volts3)use C5 hope it helpsSimone Quote
el_cuc0 Posted April 20, 2008 Author Report Posted April 20, 2008 well, i've measured the incoming power and the power going through the pots and it is stable. The incoming signal is 5.03V and fluctuates from 5.02 to 5.04, but not a really significant power fluctuation.Also, how do the commercial midi controllers get their power from usb? i have opened up my m-audio trigger finger and don't see a step-up transformer or anything obvious. Quote
cimo Posted April 20, 2008 Report Posted April 20, 2008 The incoming signal is 5.03V and fluctuates from 5.02 to 5.04, but not a really significant power fluctuation.A very fast drop of voltage can t be detected by a normal multimeter but it would be enough to crash the PIC.Also, how do the commercial midi controllers get their power from usb? i have opened up my m-audio trigger finger and don't see a step-up transformer or anything obvious.Assuming there is need for that they would use a DC-DC IC.i am not sure 100% but it is worth a try, USB is tricky (if you have USB1.1 even less power!)Simone Quote
el_cuc0 Posted April 21, 2008 Author Report Posted April 21, 2008 My trigger finger uses alpha sliders and linear pot's. However, the dc-input plug requires a 9V adapter. I connected opened MIOS Studio and got absolutely no signal, but got signal on midimon. It's not my midi interface or plug because I use them frequently. I even used them today on a mix. In regards to your recommendation to using a stable 5V supply, will the addition of the 7805 stabilize the power. :-\ Quote
nILS Posted April 21, 2008 Report Posted April 21, 2008 Adding an 7805 to a 5V supply is not a good idea as the voltage regulator has a voltage drop itself. This means you need to feed it at least 7V to get your stable 5V.As I don't see this mentioned I'm just really curios as to how you installed the application on the PIC without MIDI In. I'm assuming what you keep getting is an upload request every 2 seconds. Quote
el_cuc0 Posted April 21, 2008 Author Report Posted April 21, 2008 i bought a pre-programmed chip from smash tv. Quote
doc Posted April 21, 2008 Report Posted April 21, 2008 As I don't see this mentioned I'm just really curios as to how you installed the application on the PIC without MIDI In. I'm assuming what you keep getting is an upload request every 2 seconds. i bought a pre-programmed chip from smash tv.Ok. So you have MIOS on your PIC.But you need to upload an applikation via MIDI before you can use your Box. You will of course need a midi-In!greetsDoc Quote
el_cuc0 Posted April 21, 2008 Author Report Posted April 21, 2008 That's what I don't understand. I bought a preprogrammed chip that is supposed to have everything i need, why do i have to upload anything? I never anticipated sending instructions to my device so that is why i never put in the Midi in components. I'll do that tonight and post an update. In the meantime, any other ideas? Quote
nILS Posted April 21, 2008 Report Posted April 21, 2008 There are no other ideas - THAT IS the problem.How could smash know what box you intend to build with the PIC you bought? There's about 20 different apps + tons of custom ones. You bought a PIC with an operating system on it - not the application you'll actually run on the OS. Hence you did buy a preprogrammed chip, but not one that has all the stuff on it that you'll need. If you can link me to any page that says that it's got everything on it you'll need, I'll give you a cookie. Leaving out the MIDI In parts is definitely not a (wise) choice ;D Quote
el_cuc0 Posted April 21, 2008 Author Report Posted April 21, 2008 Thank you so much! I am leaving work now to take care of that. I completely misunderstood that concept. Quote
stryd_one Posted April 22, 2008 Report Posted April 22, 2008 Also, how do the commercial midi controllers get their power from usb?USB power is already regulated 5V DC.That's what I don't understand. I bought a preprogrammed chip that is supposed to have everything i need, why do i have to upload anything?Yeh you bought a PC with Windows on it, that should do everything, right? :D That chip only has the bootloader and MIOS - that's the operating system, not the application.I never anticipated sending instructions to my device so that is why i never put in the Midi in componentsThen you haven't read enough. Read the wiki. Read ucapps.deIn the meantime, any other ideas?Follow my signature's advice ;) When you do, you will find the midi troubleshooting guide. Do that. All will be well in no time ;) Quote
el_cuc0 Posted April 22, 2008 Author Report Posted April 22, 2008 I've researched for 4 months. In fact, I've done enough research that I was able to anticipate specifically you posting comments about me not doing enough research if i were to post a question about something I couldn't find the answer to on my own. Sometimes it's about not knowing what questions to ask. Quote
nILS Posted April 22, 2008 Report Posted April 22, 2008 I've researched for 4 months. In fact, I've done enough research that I was able to anticipate specifically you posting comments about me not doing enough research if i were to post a question about something I couldn't find the answer to on my own. Sometimes it's about not knowing what questions to ask. Don't jump on stryd_one - someone's gotta be the bad guy that points out the obvious: If you've researched for 4 months and didn't know there's different applications, you seriously need to work on your research skills.Let us know when the MIDI In components are stuffed - hope it all works well from now on :D Quote
el_cuc0 Posted April 23, 2008 Author Report Posted April 23, 2008 ok, stuffede the midi in components, was able to get sysex id to popup in mios. have dled the midibox64 application... thanks to you guys! have gone in the asm and have made basic changes such as number of pots and deactivation of mux since im only using 4 pots. however, im not getting an upload request. just giving you guys an update of my progress, looking into upload requests and such. any tips would be appreciated at this point.also, i was just teasing stryd. as i was typing in this post, i had a gut-feeling i was gonne get told to search and blah blah blah. I just get so fried from all the research after a hard days work crunching numbers and doing presentations all day that it makes my comprehension of the research challenging. you know that fuzzy feeling you get in your eye-socket and eyelids? that's me 120 hours a week. lol :o Quote
nILS Posted April 23, 2008 Report Posted April 23, 2008 Check stryd_one's signature, the link will take you to a wiki page that has some info and a link on MIDI Troubleshooting - go through that step by step. That should solve your problems - if it doesn't ask :-) Quote
el_cuc0 Posted April 23, 2008 Author Report Posted April 23, 2008 ok, so i was getting an upload request the entire time. I dled midi-ox and i have uploaded the application. looking to get to next step, i'll get back with you guys. Quote
