@stryde_one
yes they are ... the - lines of the elkos are below, so the + side should be on the top ... i think that ist ok. all elkos are build the same direction
äääähmmm at the bottom ... i thought the strong lines in the scheme were the - of the elkos :D
waaa thanks that is  a great tip! but  watching at this wikipedia pic it shows that the strong line in schemes is the - of the elko ... also on the prebuild boards of smash tv ... so if you say i should turn all 4 elkos i will do that but i cannot believe  :o
ps: the view of the pic of the wireing is turned around! so it's exactly mirrored to the upper view. the - o the elkos show alwas in the direction of the 79 ...
Yeh, when I look at the schem and how it should work, I'd say that the - of the elko should be on the bottom, so they aren't backwards...
I dunno man, I give up.
Told you that the bipolar transformer was the way to go ;)
:o :D ??? ::) 8)
puh ... so i'm glad that i'm not the only one not having an idea what the problm can be :)
i guess i'll rebuild the hole circuit a third time and then with the rectifier and a dual transformer ... hoping that solves the problem ... but thanks for the try! i was real getting mad about that  :-X
Amazing how this pretty simple circuit tends to mess with people all the time :-) Let's hope your third build will work!
(Maybe someone needs to write a step-by-step 100% foolproof tutorial on that one [not gonna be me]) :D
Who else has tried this design before?
when it comes to the bipolar transformer, it's hard to go past northernlightx's thread...
hehe
it's me again :D
10x 7912 and a few hours later i have built the circuit with two transformers and a rectifier after it .... the problem is still the same the 7912 gives me -17-18V maybe reichelt and hartnagel electronics haven't sold the best ones
+12v does work as in the first ones
i'll check the hole circuit in the next few days and hope it'll be just human missunderstanding  but for today i 'ts  enough  :o ::) 8)
looking from top the upper one is the 7812 the lower 7912 sry for bad quality of the picture  8) ::) :P
can the elko caps be too big with 2200uF for double transformer version and 4400 uF for single transformer version
  • 4 years later...
Hi all,
i digged out this old topic because i had the same problem.
There was -17V on the 7912 output.
Finally it turns out that it was  increasing to -12V on load.
Maybe this info is usefull for somebody else.
Marxon
