napierzaza Posted May 6, 2008 Report Posted May 6, 2008 I have made a SID that is comprised of one CORE and two SIDS attached to it (in the same way that Wilba wired two SIDS together on his unit. I have looked at the different control surface options and am wondering, what do I really need for my unit? I appears as if Control Unit C is too complex for me, and B is more so about if you have multiple slaved SIDs. So if I want a decent control of my sid does surface B offer me any benefit?Also, I can't find any schematics for wiring on the site. I found this one, but am unsure which Step it is. Also, does this work with SID v2?http://ucapps.de/midibox_sid_cs/2x20_enc_multi_w_j5.pdf Quote
sineSurfer Posted May 6, 2008 Report Posted May 6, 2008 Hi napierzaza, it all depends on how much you want to work on your control surface, so only you can make that decision, and based on your choice you'll have to change the setup file according to your own wiring e.g. self etched boards to hold everything, just stripboard and a lot of spaghetti wiringsCheck my mbSid stereo version, for me it was a good compromise between no CS and full CS(still needs a lot of code mods for the CS to work 100%) the whole CS is made on 3 diy boards, the harder was the one for the c64 keys + 1 stripboard for the top right encoder and leds, add to that a 4xDIN, 1 core, 2 mbSid modules.btw. there are wiring pdfs available on www.ucapps.de for DIN and DOUT modules(TK's default configs I think). Quote
TK. Posted May 6, 2008 Report Posted May 6, 2008 Hey, is this already the final pic? The panel looks more beautiful than expected from the first pictures!Definitely a reference design for small & still ergonomic solutions :)Best Regards, Thorsten. Quote
napierzaza Posted May 6, 2008 Author Report Posted May 6, 2008 Your setup is pretty low key. You had to use a DIX4x? This is interesting, I may want to do the same.BTW, I don't believe I see any links to wiring schematics.Many, the panels that you guys have made! I can barely afford to get the actual hardware together, much less a shiny panel Quote
sineSurfer Posted May 6, 2008 Report Posted May 6, 2008 thanks TK, yeah you may say it is the final pic, not totally sure about the panel, maybe I'll order one from FPE. i'll post some more pictures after all the code work is done to call it 100% functional :)napierzaza: I used a 4xDIN cos I had a module from smashTv already, so there are some unused pins hehee, and about the panel it's all diy, it just takes a lot of patience and tools... and not so perfect if you look more closely, .Forgot to tell before: there is also a LTC module, waiting to be added to the box(LEDs and back panel midi jacks are already in place)btw. thanks to Fossi advice I switched from a DOUT module to J5 on the Core for the LEDs, one module free for other projects! Quote
napierzaza Posted May 8, 2008 Author Report Posted May 8, 2008 I've been hijacked! Can someone post a link for control surface schematics before he posts more photos? Quote
nILS Posted May 8, 2008 Report Posted May 8, 2008 I've been hijacked! haha :DsineSurfer == copyCat³ == thread-hijacker™ Quote
sineSurfer Posted May 8, 2008 Report Posted May 8, 2008 lol, involuntary hijack though, no more photos from me on this thread ;D"sineSurfer == copyCat³ == thread-hijacker™"All learned from my guru fossi Quote
