Theta_Frost Posted June 4, 2008 Posted June 4, 2008 I have some quick questions. :P First is I read the wiki but I still don't understand AOUT DOUT AIN DIN what is there function?Also what would I need for a complete control surface with only one sid. From what I know its a core module, a sid module, and then what? Basically I want a full fledged Midibox Sid with only one sid. Thanks for the help, You guys are the best!
cosmosuave Posted June 4, 2008 Posted June 4, 2008 Complete Control Surface (Step C)DescriptionAdditional parts and modules:n x core modulesm x SID modulesthe minimal control unit (see above)an improved PSU (ca. 1A) - the C64 PSU should be prefered due to the seperate +5V output for the core module(s) 3 DINX4 modules2 DOUTX4 modules14 additional rotary encoders (in difference to the datawheel, non-detented encoders are recommented here, but detented will also work fine, for example M-SW-ROT from Voti or the Bourns encoders from SmashTV's Shop)32 additional buttons99 LEDsca. 2-3 veroboards for mounting the buttons/encoders/LEDsa nice frontpanelCosts: most expensive parts are the rotary encoders (ca. 15 EUR) and especially the frontpanel (selfmade ca. 25 EUR + a lot of time, premade ca. 100..150 EUR!)
Pascal Posted June 5, 2008 Posted June 5, 2008 TK uses the CS-Step CIn the Manual you can see the OLD Version of CS-Step 3. The LED-Matrix have now a 8. Line his calles Volume. You can select the SID Module per core (Left and Right).Here a List what the Modules are do:AIN: Analog InputThats for Controle Voltage appsAOUT: Analog OutputControle Voltage Outputs to controle Filters or SynthsDIN: Digital InputsFor Rotare Encoders or Switches also . . .DOUT: Digital OutputFor LED´s or 7-Segemnts LED-DisplaysFor CS Step3 you need 3 4xDIN Modules and 2 4xDOUT Modules (look at the standart DINPUT and DOUTPUT Shematic at the SID_Manual).and then the Encoders, Switches an LED´s.
Theta_Frost Posted June 5, 2008 Author Posted June 5, 2008 By 3x4 din do you mean 12 modules? sorry :'( i dumb
unrise_lyrical Posted June 6, 2008 Posted June 6, 2008 ooh, ooh, thats a question I think I can answer! on uCapps there are different versions of the DIN module listed. he means 3 DIN modules which have the 4 "74HC165" ICs.here is a schematic off uCapps:and here is an example of a 3DIN module:anyone feel free to correct me if im wrong, and bludgeon me over the head with a hammer :P
stryd_one Posted June 6, 2008 Posted June 6, 2008 Just a sidenote, it may pay to be precise with the terminology to avoid confusion. a DIN is one single pin, which you would connect to a switch. A DINx4 is a module with 4 Shift registers on it, each one having 8 DIN's.So, those pictures are a DINx4 and DINx3 module.
Theta_Frost Posted July 21, 2008 Author Posted July 21, 2008 Okay sorry for bump but get me right, (I know will be using 2 SIDS) I need 46 buttons, 99 LEDS, 15 rotary encoders (I thought I needed pots?), 3 DINX4, 2 DOUTX4, 4X20 LCD (I like that one best), and the veroboards. Thanks I'm sorry for my nuisances! :-X
buhler Posted July 21, 2008 Posted July 21, 2008 with things like buttons, LED's and Encoders, etc.. i would order WAY more than you think you need because you are most likely going to use them on other projects... especially seeing as you've posted your build list a few times in other threads. ;)
Theta_Frost Posted July 21, 2008 Author Posted July 21, 2008 Haha thats right, I'm doing my initial megaparts order soon for lots of future projects because I'm finally getting a decent work area set up! :P
