Theta_Frost Posted June 5, 2008 Posted June 5, 2008 Where can you find a list for all the parts that go on the OPL3 module, because I noticed smash doesn't sell them in kits. Also as I am starting to build my Midibox SID and FM I will try to make a walkthrough and detail how i did. Thanks and you guys rock.
cimo Posted June 5, 2008 Posted June 5, 2008 Where can you find a list for all the parts that go on the OPL3 module, because I noticed smash doesn't sell them in kits. Also as I am starting to build my Midibox SID and FM I will try to make a walkthrough and detail how i did. Thanks and you guys rock.... in the OPL3 module pagehttp://www.ucapps.de/mbhp/mbhp_opl3_orderlist.txt
Theta_Frost Posted June 6, 2008 Author Posted June 6, 2008 Ooh thanks, also on Smashes site it say you need jumpers, is that just a wire on the red line? Thanks
nILS Posted June 6, 2008 Posted June 6, 2008 When those jumper wires run close to components you might want to use isolated cables instead of cut resistor legs.
bugfight Posted June 6, 2008 Posted June 6, 2008 ...cut resistor legs.cut resistor legs are now considered inhumane and therefor cut resister leads should be used instead by all conscientious boxers, preferably .1% for audio paths...
