I must say that I haven't expected this quality from a 8580. At many websites you can read that the filter of the 8580 are worse compared to the 6581, so I didn't try to improve the sound until last week - the result is amazing.
No, the 6581 filter cannot be improved. They have a very warm, but sometimes also slushy (german: "matschig") and distorting sound. The cutoff frequency goes over the whole 11 bit range.
The 8580 filters have a limited range of only 9 bit (sometimes you will hear "clicks" when sweeping the values very slowly), but it sounds precise and strong. Also the signal/noise ratio is much better (less than -90 dB)
However, due to the different characteristics it makes sense to use both chips in a 4*SID box (like me :)) For example, the distorting lead sound from the mbsid_demo8.mp3 cannot be realized with a 8580..
I just have uploaded a MP3 which compares the two filters on a very extreme situation: an evelope sweeps the frequency over the whole cutoff range. Btw: the sample is the absolute MP3 killer, a bitrate below 320 results into a lot of digital noise:
http://www.ucapps.de/midibox_sid/mbsid_v1_5_filter.mp3
1) 6581 with low-pass
2) 8580 with low-pass
3) 6581 with high-pass
4) 8580 with high-pass
wow! both sound killa T :) they both have they're own sound for def - equally useful tho i think...;)
Nice...
Dan
So I just will built the 4x6581 SID. Sounds dammit cool.
And then, in some time, I´ll just built an 4x8580 one!!!  ;D *HARHARHAR* DOUBLE SID POWER!!! (and much more less money then...  ;D)
Can´t wait to start build again!
To make things clear to me:Can I have two 6581 and two  8580 in the same box and use the C64 PSU??
Should I make the slave CORE with the PIC16F or the 18F or does it matters? (for the future).....
Thanks
Christoffer
Hi Christoffer,
yes, you can use the PSU either of the new or of the old C64 for the 6581 and the 8580 - both units deliver 5VDC and 9VAC (note that the additional 7809 shifts the voltage level to +5VDC+9VDC = 14VDC).
My own MIDIbox SID is stuffed with two 6581 and 8580 - in my oppinion the best combination :)
Currently it doesn't matter if you are using the PIC16F or PIC18F for the slave cores, but I'm not sure how long I can ensure the availability of the same features for both firmwares (yes, the next V1.5 release will be 1:1 compatible, although my effort for the implementation of the PIC16F adaption was about 4 times higher than for the original PIC18F solution!).
So, if you don't already own some old PIC16F, use PIC18F. The PIC18F provides also a much larger MIDI buffer which prevents stucking notes!
