This N°9 Posted September 21, 2008 Report Posted September 21, 2008 DSP:My plan is to find a cheap mini/nano atx box, with linux and pure data installed and properly flagged to run at startup, athere is even a pico-itx-board, which is ca. 10x7.2 cm in size:http://www.mini-itx.com/reviews/pico-itx/default.asp?page=1http://www.via.com.tw/en/initiatives/spearhead/pico-itx/via technical white paper is attached to the post.a usb-drive could serve as system-drive. link to midi-box via usb-midi or ethernet or something else.pico-itx_form_factor.pdf
cimo Posted September 21, 2008 Report Posted September 21, 2008 DSP:there is even a pico-itx-board, which is ca. 10x7.2 cm in size:http://www.mini-itx.com/reviews/pico-itx/default.asp?page=1http://www.via.com.tw/en/initiatives/spearhead/pico-itx/via technical white paper is attached to the post.a usb-drive could serve as system-drive. link to midi-box via usb-midi or ethernet or something else.yeah how sweet is that?but since i am planning to embedd a system behind a 17 inches LCD i can t see the use for such a small mobo but, who knows?it all still looks too freash and young to be stable enoughHas anybody ever seen 90 degrees adaptors for PCI slots?
This N°9 Posted September 21, 2008 Author Report Posted September 21, 2008 yeah, actually a mini or nano is cheaper. if there is enough space, this wouldbe the better choice.pico itx: ca. 220 euro (CPU onboard)micro itx (17x17cm): ca 130-200 euro (CPU onboard)DC-DC adapter (input 12VDC): ca. 50 euro+ RAM / heatsink / fan
stryd_one Posted September 22, 2008 Report Posted September 22, 2008 Has anybody ever seen 90 degrees adaptors for PCI slots? Yep :) The keyword you want is "riser"Google hit #3 for 90degree pci riser is this: http://www.colomachine.com/colomachinev2/Accessories/Items/PCI-Riser/RC-1UR-PCI-KIT.htmIs that what you wanted?
cimo Posted September 22, 2008 Report Posted September 22, 2008 Yep :) The keyword you want is "riser"Google hit #3 for 90degree pci riser is this: http://www.colomachine.com/colomachinev2/Accessories/Items/PCI-Riser/RC-1UR-PCI-KIT.htmIs that what you wanted?aah RISER ! nice, bit expensive though but i think this is not stuff that you can dity etch at home, due to the high speed data transfers.Ebaying around i ve found this:http://cgi.ebay.de/Industrie-PC-Mainboard-SBC-NOVA-7830-Tualatin-1200_W0QQitemZ180291193996QQcmdZViewItem?hash=item180291193996&_trkparms=72%3A1124|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14it s got also a direct connection to LCD screens...but this is drifting offtopic and needs a new thread in miscellaneous nowEDIT: tx TK
lucem Posted September 23, 2008 Report Posted September 23, 2008 Look at the NGW100 from Atmel while you're at it.Costs around $89, I'm really contented with what it has to offer :)
cimo Posted September 23, 2008 Report Posted September 23, 2008 mmm i need something with *Ghz on the CPU
stryd_one Posted September 23, 2008 Report Posted September 23, 2008 Is there much in the way of DIY projects around that beastie yet? (the NGW)Something else worth considering is an asus eeebox... They're numerous, so they're cheap, and there's lots of support. About the size of a hardback at 223x178x26mm...no PCI slots but plenty of USB, and WLAN built in, etc... at 350USD it's more than the parts for a real embedded system, but you might save a lot of hassle...
Goblinz Posted September 23, 2008 Report Posted September 23, 2008 Is there much in the way of DIY projects around that beastie yet? (the NGW)Something else worth considering is an asus eeebox... They're numerous, so they're cheap, and there's lots of support. About the size of a hardback at 223x178x26mm...no PCI slots but plenty of USB, and WLAN built in, etc... at 350USD it's more than the parts for a real embedded system, but you might save a lot of hassle... They're pretty hackable too, do a search and you'll see. They also run SUSE quite nicely.
Goblinz Posted September 23, 2008 Report Posted September 23, 2008 Another option would be to install Linux on to an old wireless router and use that.... I'm sure this is possible but haven't down the research so am unsure on specs or what could be done with it. G
cimo Posted September 23, 2008 Report Posted September 23, 2008 All nice proposal but show me something with OpenGL on the video card and minimum 1Ghz CPU and i am game.
