boops Posted September 25, 2008 Report Share Posted September 25, 2008 Hi,friend programmer,,i thought with Reboot (this is his picture) to swap the fm matrix with 24 icecubes and 24 tact switches under, do you think the modification of .ASM (hex)will be difficult -or perhaps impossible)...imagine 24 beautiful icecube switches(blue,red ,or yellow) and with only one finger toggle the parameter ...dream...or reality?i will redesign the front panel for....thanks for your response.. B :) :( P's Quote Link to comment Share on other sites More sharing options...
nILS Posted September 25, 2008 Report Share Posted September 25, 2008 Possible. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted September 25, 2008 Report Share Posted September 25, 2008 Also, yum. Quote Link to comment Share on other sites More sharing options...
TheAncientOne Posted October 28, 2008 Report Share Posted October 28, 2008 Now you've done it! I have a big batch of Illuminated MECs, courtesy of an Electronics Goldnmine clearence and the very kind help of Peake.Just bought enough clear caps to try this: I also wondered about using separate buttons for the instrument/operator buttons, for compatibility.I think some diodes might see the thing working with very little code reworking, seeing the way TK did it. Key rollover might be a problem, though no worse than of two row buttons were pressed anyway.Have I caught the madness? Only time will tell! Quote Link to comment Share on other sites More sharing options...
reboot Posted October 29, 2008 Report Share Posted October 29, 2008 prof...mec from Electronics Goldnmine are cheap ...where did you get the caps ? Quote Link to comment Share on other sites More sharing options...
TheAncientOne Posted October 29, 2008 Report Share Posted October 29, 2008 I got mine from Rapid in the UK.www_rapidonline_com - MEC CapsThe ones I ordered were the 16mm 'thin' ones.The square ones, (expensive!) are good for some jobs, because you can open them up and put lettering inside. Too much for a MIDIbox FM, but I did use one for the Zero crossing switch on my Marc Bareille 'Quantix 8' m_bareille_free_fr - Quantix 8, I've not done the panel yet, but i'm trying for that old style computer/instrument look. A whole panel of them in a grid would look amazing for the FM, but nearly £40 worth of caps is too much for me, sadly. Quote Link to comment Share on other sites More sharing options...
reboot Posted November 7, 2008 Report Share Posted November 7, 2008 thank you for info...again rapid ! Quote Link to comment Share on other sites More sharing options...
boops Posted April 26, 2009 Author Report Share Posted April 26, 2009 hi the Proof,after a LONG changing home ,my MBFM works,where are you with the new code of the soft? ;) Quote Link to comment Share on other sites More sharing options...
strophlex Posted June 5, 2009 Report Share Posted June 5, 2009 Hi! boobs, how did you do it. What did you change? Also, did you separate the Op/Ins buttons to be used by the ice cubes? Quote Link to comment Share on other sites More sharing options...
boops Posted June 6, 2009 Author Report Share Posted June 6, 2009 hi not boobs please ;)it's boop's....unlucky,nobody for programming a new code... my control surface is not finish yet,i 've just planed to finish it with a ssm 2044 filter...for the moment...best regards thanks ,for the interest.... Quote Link to comment Share on other sites More sharing options...
strophlex Posted June 8, 2009 Report Share Posted June 8, 2009 hi not boobs please ;)it's boop's....unlucky,nobody for programming a new code... my control surface is not finish yet,i 've just planed to finish it with a ssm 2044 filter...for the moment...best regards thanks ,for the interest....I misunderstood. I thought you completed the project, but I see you are just finnished with the midibox modules. Anyway I might do something similar. I'll keep posting when/if I do that. Quote Link to comment Share on other sites More sharing options...
