MIOS Studio Beta 8^H9 with improved robustness
A new MIOS Studio version is available which got a lot of improvements to improve the robustness.
  -> http://www.ucapps.de/mios_download.html
E.g., there was an error in the retry handling which corrupted the flash content under special circumstances. Accordingly, everybody is strongly recommented to use this new version to avoid, that MIOS or even the 1st level bootloader has to be installed again after a failing application upload.
...or even the 1st level bootloader has to be installed again after a failing application upload.
...this happend to me twice.
Linux :
java -jar MIOSStudio_beta8.jar &
No Problems here. Thanks for the improvements!  :)
Hi TK,
I had a bit of a play with this new version, uploaded the latest 3.4 Seq and tested another box as a matter of interest.
All working fine here, good job - as always :-D
Thanks as ever!
Dave mK
  • 3 weeks later...
A new version is available: MIOSStudio_beta8_3
Complete ChangeLog for v8:
  • Removed references to incomplete features in MIOS Studio
  • Added upload facility for MIOS32 platform
  • Added MIOS debug terminal for plain text output instead of cryptic MIDI messages
  • Fixed window dragging problem in MIOS Studio
  • Added Cascade Windows function to MIOS Studio
  • Merged codebases between MIOS Studio and SID V2 Editor.
  • SID V2 Editor updated to use base MIDI classes from most recent MIOS Studio
  • Different complete binaries are built from the same codebase: MIOSStudio (MIOS Studio standalone),
  • SIDV2Editor (SID V2 Editor standalone), MIOSStudioSID (MIOS Studio with SID V2 Editor integrated),
  • VirtualKeyboard (standalone MIDI keyboard and device routing)
  • Renamed "driver" classes as listed above
  • Fixed MIDI disconnecting issue under MacOS/mmj
  • Added MIDI Thru port to MIOS Studio (with option to pass traffic through OUT port as previous) and
  • Virtual Keyboard apps
  • Fixed dialog box problems (Alt-tab)
  • Moved MIDI Device selection and MIDI Filters to main toolbar, separate from MIDI Device Routing
  • Created separate Windows for LCD Message and MIOS Debug Functions
  • Added custom sliders to SID V2 Editor
  • Fixed MIDI keyboard bug (see this post).
  • Added PgUp, PgDown, Home and End keyboard inputs for all knobs.
  • Added custom backgrounds to SID V2 Editor
  • Added right-click row selection to BankTable
Note: the updated MBSID V2 Editor will be released in a separate package later.
Thanks to Adam and Rutger for keep working on the Java tools! :)
Great! Thank you Thorsten.
-> redirected to Adam and Rutger - I only pushed the release button! :)
Would you say the same if you launch the nuclear missile?  :P
Thanks Adam and Rutger. ;) Good work guys.
[me=stryd_one]blames SmashTV[/me]
<n00b> you blew up my whole city man, don't you know I have a school project due tomorrow?
  • 4 weeks later...
We reached beta9 state:
  • Moved icon and menu items for MIDI Device Routing
  • Implemented XML save/restore feature for all elements of MIOS Studio on closing/reopenning. Workspace configurations can also be saved and restored via File menu
  • MIDI Filter definitions can also be saved/restored via XML
  • Changed MIDI Device Manager handling of physical MIDI Devices. Fixes problems with mmj re-adding the same devices when rescanning, and virmidi listing multiple devices for each port.
Thanks again to Adam!
  • 4 weeks later...
