noofny Posted March 25, 2009 Author Report Posted March 25, 2009 bugfight - I can't thank you enough for taking the time to help out - have felt a bit lost with this one!first i would suggest to use Tick() or Timer() to handle your testing instead of inlining it in Init() and using MIOS_Delay()Good idea I'm familiar with that, will stay away from calling stuff in Init().try all the permutationsYeah did that over the weekend...even swapping the SR chips around for a spare set, etc. Doesn't seem to change anything.you might also try connecting the doutx4 for both arrays, but not the first array itselfDo you mean try bypassing the darlingtons altogether?if you want some suggestions on code efficiency, i can give someI would really welcome and appreciate that...didn't want to ask...if you have the time PM me your suggestions/critiques/ideas.
bilderbuchi Posted March 25, 2009 Report Posted March 25, 2009 I would really welcome and appreciate that...didn't want to ask...if you have the time PM me your suggestions/critiques/ideas.could you maybe post them in the thread, so other people could also learn some coding efficiency tricks? :)
protofuse Posted March 25, 2009 Report Posted March 25, 2009 hello,I contribute here as I worked on rgb led matrix too.The only "problem" is the fact the cathods are linked... ground is common and if I sink the current on a line, it sinks from each cathode and blip blip blip: the three colors are light up together.so transistors are here only for avoiding that!but I guess everyone understood that, if it wasn't the case, I hope it is clearer for severalI just add it several links that could help:1/ led spi interface from sparkfunhttp://www.sparkfun.com/commerce/product_info.php?products_id=760 => especially the firmware code.even if it is a spi between your core and the led driver, the matrix is connected via SR + a pretty ULN darlington arrayswatch this pdfit shows a correct rgb led driver wired!but this is incomplete without the wiring of the RGB led matrix involvedATTENTION: the matrix is " as if it was" a common anode in this sparkfun example !all the examples here are common cathode!but the philosophy is the same watch it:I thought you had to feed -v into the darlingon in's, but you feed in +v and it outputs -v. Still don't really understand how that happens but there's a lot of this going over my head - just glad it's sorted though.currents have to be sinked by the darlington.you saturate one transitor by sending +v to itit closes the circuit between the corresponding line and the ground ... so yes: the current gets out the led cathode to the ... commuted ground :)and you do it on a cycle.so now, it is complete ;)2/ unsped & Devon Jones/Octinct (+ )for those who don't know the octinct, it is a NICE and WORKING full* rgb monome clone arduino based.http://unsped.blogspot.com/Check the code it uses.no darlington, ok, but 3 transistors: one for each color.the cycle is:for all lines for all color light up this ledthe first link about that, that talks about darlington is : http://www.upwardnotnorthward.com/2008/01/my-first-project-full-colour-rgb-monome.html3/ arduinome's playground about LEDshttp://www.arduino.cc/playground/Main/InterfacingWithHardware#Output => LEDS & Display (just added the unsped link, it hasn't been added ... what a omission!!!)BTW, I began a project like noofny, I only designed things on visio and ordered 2 midibox 64 kits at Mike's shop.If I can help about that, I could easily debug when I'll wire my matrixes...but I'm sure above links provide solutions, especially the first link that shows how the hardware has to be wired!If you need help, just ask!!
protofuse Posted March 25, 2009 Report Posted March 25, 2009 I complete my previous post by this:with this, we can see that with one Darlington array + 3 SR, we could easily drive a 8x8 RGB Leds matrix :Dso... I'm going to drink a cocaCola to celebrate!I'll post more from my schematics work asap!
bugfight Posted March 25, 2009 Report Posted March 25, 2009 ok, first i think there was good reason to keep the same color leds anodes on a single sr...as a result you are wasting a lot of bits in your color arrays, and cycles setting pins instead ofwhole registers as a byte at once.but aside from that, anywhere i see the same code (or similar code) repeated i look for a better way.there are rare cases where you need to trade code efficiency for execution efficiency, but i don't thinkthese cases fall under that umbrella.note that i haven't compiled these so it's likely there are some typos...where you have: matrix_2[_MATRIX_SONG_COLUMN][0] = 0x30; matrix_2[_MATRIX_SONG_COLUMN][1] = 0x30; matrix_2[_MATRIX_SONG_COLUMN][2] = 0x30; matrix_2[_MATRIX_SONG_COLUMN][3] = 0x30; matrix_2[_MATRIX_SONG_COLUMN][4] = 0x30; matrix_2[_MATRIX_SONG_COLUMN][5] = 0x30; matrix_2[_MATRIX_SONG_COLUMN][6] = 0x30; matrix_2[_MATRIX_SONG_COLUMN][7] = 0x30; switch(evnt1-0x10) { case 0: // SONG 1 matrix_2[_MATRIX_SONG_COLUMN][evnt1-0x10] = evnt2; break; case 1: // SONG 2 matrix_2[_MATRIX_SONG_COLUMN][evnt1-0x10] = evnt2; break; case 2: // SONG 3 matrix_2[_MATRIX_SONG_COLUMN][evnt1-0x10] = evnt2; break; case 3: // SONG 4 matrix_2[_MATRIX_SONG_COLUMN][evnt1-0x10] = evnt2; break; case 4: // SONG 5 matrix_2[_MATRIX_SONG_COLUMN][evnt1-0x10] = evnt2; break; case 5: // SONG 6 matrix_2[_MATRIX_SONG_COLUMN][evnt1-0x10] = evnt2; break; case 6: // SONG 7 matrix_2[_MATRIX_SONG_COLUMN][evnt1-0x10] = evnt2; break; case 7: // SONG 8 matrix_2[_MATRIX_SONG_COLUMN][evnt1-0x10] = evnt2; break; default: //matrix_2[evnt1-0x10][evnt0-0x90] = evnt2; break; } i would have: int i; unsigned char songIdx = evnt1-0x10; for(i=0; i<8; i++) { if(i == songIdx) matrix_2[_MATRIX_SONG_COLUMN][i] = evnt2 else matrix_2[_MATRIX_SONG_COLUMN][i] = 0x30; } where you have: void DisplayLED(unsigned char column, unsigned char color) __wparam { switch(color) { case 0x00: //OFF MIOS_DOUT_PinSet(column+8, 0); MIOS_DOUT_PinSet(column+8+8, 0); MIOS_DOUT_PinSet(column+8+16, 0); break; case 0x10: // RED MIOS_DOUT_PinSet(column+8, 1); MIOS_DOUT_PinSet(column+8+8, 0); MIOS_DOUT_PinSet(column+8+16, 0); break; case 0x20: // GREEN MIOS_DOUT_PinSet(column+8, 0); MIOS_DOUT_PinSet(column+8+8, 1); MIOS_DOUT_PinSet(column+8+16, 0); break; case 0x30: // BLUE MIOS_DOUT_PinSet(column+8, 0); MIOS_DOUT_PinSet(column+8+8, 0); MIOS_DOUT_PinSet(column+8+16, 1); break; case 0x40: // CYAN MIOS_DOUT_PinSet(column+8, 0); MIOS_DOUT_PinSet(column+8+8, 1); MIOS_DOUT_PinSet(column+8+16, 1); break; case 0x50: // MAGENTA MIOS_DOUT_PinSet(column+8, 1); MIOS_DOUT_PinSet(column+8+8, 0); MIOS_DOUT_PinSet(column+8+16, 1); break; case 0x60: // YELLOW MIOS_DOUT_PinSet(column+8, 1); MIOS_DOUT_PinSet(column+8+8, 1); MIOS_DOUT_PinSet(column+8+16, 0); break; case 0x70: // WHITE MIOS_DOUT_PinSet(column+8, 1); MIOS_DOUT_PinSet(column+8+8, 1); MIOS_DOUT_PinSet(column+8+16, 1); break; default: break; } } i would have: void DisplayLED(unsigned char column, unsigned char color) __wparam { color >>= 4; MIOS_DOUT_PinSet(column+8, (color & 0x01)); color >>= 1; MIOS_DOUT_PinSet(column+8+8, (color & 0x01)); color >>= 1; MIOS_DOUT_PinSet(column+8+16, (color & 0x01)); } where you have: void SR_Service_Prepare(void) __wparam { static unsigned char row; static unsigned int x; row = ++row & 0x0F; MIOS_DOUT_SRSet(0, 0); MIOS_DOUT_SRSet(4, 0); switch(row) { case 0 : { MIOS_DOUT_PinSet1(row); MIOS_DOUT_PinSet1(row+32); for (x = 0; x < 8; x++) { DisplayLED(x, matrix_1[row][x]); DisplayLED(x+32, matrix_2[row][x]); } break; } case 1 : { MIOS_DOUT_PinSet1(row); MIOS_DOUT_PinSet1(row+32); for (x = 0; x < 8; x++) { DisplayLED(x, matrix_1[row][x]); DisplayLED(x+32, matrix_2[row][x]); } break; } case 2 : { MIOS_DOUT_PinSet1(row); MIOS_DOUT_PinSet1(row+32); for (x = 0; x < 8; x++) { DisplayLED(x, matrix_1[row][x]); DisplayLED(x+32, matrix_2[row][x]); } break; } case 3 : { MIOS_DOUT_PinSet1(row); MIOS_DOUT_PinSet1(row+32); for (x = 0; x < 8; x++) { DisplayLED(x, matrix_1[row][x]); DisplayLED(x+32, matrix_2[row][x]); } break; } case 4 : { MIOS_DOUT_PinSet1(row); MIOS_DOUT_PinSet1(row+32); for (x = 0; x < 8; x++) { DisplayLED(x, matrix_1[row][x]); DisplayLED(x+32, matrix_2[row][x]); } break; } case 5 : { MIOS_DOUT_PinSet1(row); MIOS_DOUT_PinSet1(row+32); for (x = 0; x < 8; x++) { DisplayLED(x, matrix_1[row][x]); DisplayLED(x+32, matrix_2[row][x]); } break; } case 6 : { MIOS_DOUT_PinSet1(row); MIOS_DOUT_PinSet1(row+32); for (x = 0; x < 8; x++) { DisplayLED(x, matrix_1[row][x]); DisplayLED(x+32, matrix_2[row][x]); } break; } case 7 : { MIOS_DOUT_PinSet1(row); MIOS_DOUT_PinSet1(row+32); for (x = 0; x < 8; x++) { DisplayLED(x, matrix_1[row][x]); DisplayLED(x+32, matrix_2[row][x]); } break; } default : { break; } } } i would have: void SR_Service_Prepare(void) __wparam { static unsigned char row; unsigned int x; //edit* just noticed, no reason for this to be static row = ++row & 0x07; //<-- here you were cycling 16 rows i think you meant 8, no? //this would have resulted in a 6.25% duty cycle (vs 12.5%). //note that the duomatrix uses a 25% duty cycle MIOS_DOUT_SRSet(MATRIX1_DOUT_START, 0);//<-- hardwire bad, napster good. define constants MIOS_DOUT_SRSet(MATRIX2_DOUT_START, 0);// so you can move your matrix in the chain MIOS_DOUT_PinSet1(row + (MATRIX1_DOUT_START * 8)); MIOS_DOUT_PinSet1(row + (MATRIX2_DOUT_START * 8)); for (x = 0; x < 8; x++) { DisplayLED(x + (MATRIX1_DOUT_START * 8), matrix_1[row][x]); DisplayLED(x + (MATRIX2_DOUT_START * 8), matrix_2[row][x]); } }
protofuse Posted March 25, 2009 Report Posted March 25, 2009 bugfight, the code you made is to use with the first schematic from noofny or another (one of those in my link) ??I found a mistake in the schematic, hope noofny didn't make it in the real world.the "common" pin (pin 9 for the ULN2003 and 10 for the ULN2803) isn't linked to ... ground in our case.personally, and probably, I'll do that:bugfight? what do you think about that and about the code we can use for it ?by sending bytes from the CORE to the DOUTx4, we successively commute the rows of the matrix to the ground and light up colors in the line successively:for line for color light up all led in the line with current colorthe only question I have: does it flicker......................?indeed, at a time, one color of a led in one line is up...I'm afraid about that.I have to dive more inside the midibox framework in order to figure out how timers are used ..because: handle pots, buttons, and ... making so quick needed cycles... I guess it requires asynchronous stuff.. (thread..)but i'm sure it already exists in this powerful framework
protofuse Posted March 25, 2009 Report Posted March 25, 2009 as I'm just as the beginning of my project, I cannot test it by myself, but... I almost understood how it can work..the schematic of noofny, with the verification and eventually fixed thing about the ground of pin 9 (or pin 10 with ULN28003) may work fine!in order to avoid flickering, I guess we have to use an interrupt service routine.it is a process called periodically AND independently of the main routine.I read this a long time ago about interrupt and timer of arduino board (atmega8 controller)As described here, we have to use the timer2 and a particular interrupt.indeed, the timer 0 is the clock referencetimer1, timer2 takes timer0 as a referenceso, we can "hijack" timer2 for our use ///////////////////////////////////////////////////////////////////////////// // This function is periodically called by MIOS. The frequency has to be // initialized with MIOS_Timer_Set ///////////////////////////////////////////////////////////////////////////// void Timer(void) __wparam { }I'd like to put inside this Timer(void) function the cycle we talked about above.pratically, it should work like that:main functions => handle button (via DIN SRs) + handle pots (via AIN SRs)interrupt called functions => handle RGB Leds matrix (called via an interrupt)why shouldn't we OVERload the Timer(void) function ?it is easy: when it will be called, the system ONLY care of what it will be inside this function.. it means: no functions from the main thread works!!...thus it is called i n t e r r u p t... pretty and cool name and ... indeed the appropriated name ;)basically, it means: no pots handling, no buttons handling during the interrupt time (= the driving leds matrix time)I'll code something asap.but as I said, I cannot test it.so, probably, we'll work with noofny (one in France, the other in Australia...!)but the solution is near... and others had done it before (example: the monodeck II)
protofuse Posted March 25, 2009 Report Posted March 25, 2009 bugfight, USER_SR_Service_Prepare is an ISR too... (sorrrrrry!)so probably, your code works like that and works with efficiency ... :)noofny, I guess it could be useful to make one core drives one matrix, and the other one the other matrixbecause of overloading risk of ISR..experts, what do you think about that?
protofuse Posted March 27, 2009 Report Posted March 27, 2009 bugfight, noofny, any infos about all of that?I'll probably work on the code asap (this day... in the next hours as here: it is 11AM!cheers
noofny Posted March 29, 2009 Author Report Posted March 29, 2009 sorry have been away from the project for a few days...needed a break....thanks bugfight and julian for your posts. Had a quick look over the code changes and think I understand them all so will be refactoring the code tonight and will post the results.Apart from that - so long as I dont try light up all the LED's as white things are working so at least it's not a show stopper!
noofny Posted March 29, 2009 Author Report Posted March 29, 2009 have implemented all the advised changes and not only does everything still work but things seem to be working better...not yet tested lighting up both matrix's full tho...has been a good learning task.bugfight - thanks so much mate - I owe you a beer - what do you drink? 8)
bugfight Posted April 3, 2009 Report Posted April 3, 2009 ...bugfight - thanks so much mate - I owe you a beer - what do you drink?...no problemo, my tiny contributioni'm not drinking anything due to a bad vodka experience last week.buy tk a beer instead...
noofny Posted April 4, 2009 Author Report Posted April 4, 2009 haha...well thanks all the same bugfightTK can i buy you a beer through paypal...? :D
protofuse Posted April 6, 2009 Report Posted April 6, 2009 yeah!it is a great news noofny.my contribution doesn't deserve a beer (or a coca cola)bugfight did the trick :)thanks to him too!I just hope to test all of that ASAP!
protofuse Posted April 19, 2009 Report Posted April 19, 2009 any ideas about resistors value for the darlington array legs ???for the leds, I guess it can be calculated easily by hand or by this kind of tool: http://led.linear1.org/led.wizby putting 1 as the led number and 5V as source voltage... and the datasheet value for I values...but for the transistor array ?????
J Martins Posted April 19, 2009 Report Posted April 19, 2009 Maybe this web site will help you proto:http://ledcalc.com/
Gridracer Posted April 19, 2009 Report Posted April 19, 2009 Hello protofuse,you do not need resistors on the UL N2803.I use the same circuit like you in my box (Midibox SEQ).The circuitplan and an introduction how to easily add the UL N2803 IC to a standard DOUT x4 PCB can be found here:http://www.midibox.org/forum/index.php?action=dlattach;topic=13118.0;attach=4666
protofuse Posted April 19, 2009 Report Posted April 19, 2009 indeed... the loard resistor are already on the lines ("before" the leds..) so ... it doesn't require another oneI'll use a 2803 (18 pins..) so I have to re-check that to directly put it on the DOUTx4 module..I think I'll do a thing like mike/noofny: not sure yet :)
turkishboy Posted June 22, 2009 Report Posted June 22, 2009 hi boysMy name is sinan from turkeysorry my english is poorplease help me for rgb led i like these project http://www.suckow.de/ralf/ledmatrix4x20/sombody help me pleasee I want to do itIf you can help me if you have graduatedSorry for my english,I'm waiting for good news
protofuse Posted June 22, 2009 Report Posted June 22, 2009 hello,you can check the noofny project here: http://noofny.blogspot.com/or mine here: http://www.julienbayle.net/diy/protodeck/blog/mine is not finished, but I tweaked the code to fit my hardware.feel free to send me an email :)
turkishboy Posted June 22, 2009 Report Posted June 22, 2009 sorry i dont want these project i want only rgb led v meter like these these professional but we can boyss We should do itDo you want to help___??
protofuse Posted September 21, 2009 Report Posted September 21, 2009 hello,6 months after, I'm almost ok with my deck.I use the same code that the one of noofny, but I don't have 2 DOUT on the same core: I have one DOUT on each core.I made a modification and I'm using smashTV DOUT with 4 SR, 3 resistor arrays + 1 ULN2803.The ULN2803 pin9 is clamped to GND, the pin 10 isn't connected to nothing (the mistake is here ....????)I attached the main.c & main.h of the core 1 but I did the same thing for led handling for the core 2.The code of noofny works fine for his 2 DOUT chained, I altered it to make it working with my solo DOUT...BUT it doesn't work!the code part to look at are :void DisplayLED(unsigned char column, unsigned char color) __wparam { color >>= 4; MIOS_DOUT_PinSet(column+8, (color & 0x01)); // RED color >>= 1; MIOS_DOUT_PinSet(column+8+8, (color & 0x01)); // BLUE color >>= 1; MIOS_DOUT_PinSet(column+8+8+8, (color & 0x01)); // GREEN } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS before the shift register are loaded ///////////////////////////////////////////////////////////////////////////// void SR_Service_Prepare(void) __wparam { // HELPED BY BUGFIGHT ON MIDIBOX - http://www.midibox.org/forum/index.php/topic,12786.0.html static unsigned char row; unsigned int x; //edit* just noticed, no reason for this to be static row = ++row & 0x07; //<-- here you were cycling 16 rows i think you meant 8, no? //this would have resulted in a 6.25% duty cycle (vs 12.5%). //note that the duomatrix uses a 25% duty cycle MIOS_DOUT_SRSet(_MATRIX_DOUT_START, 0); //<-- hardwire bad, napster good. define constants // so you can move your matrix in the chain MIOS_DOUT_PinSet1(row); for (x = 0; x < 8; x++) { DisplayLED(x , matrix[row][x]); } }could someone help me a bit?all the best,main.cmain.hmain.cmain.h
protofuse Posted September 22, 2009 Report Posted September 22, 2009 no problem.it shouldn't be a code problem.my matrix isn't common cathode... but common anode.thanks besthongkong ! I ordered common cathode, you sent common anode...if I wasn't a newbie, of course I'd check it before soldering but ...btw, thanks to lucem. he detailed me how I can make it works with darlington and BC547 too...I guess it will work ... tomorrow!all the best
noofny Posted September 23, 2009 Author Report Posted September 23, 2009 well done dude! shame about besthongkong...you should be able to return hopefully
protofuse Posted September 23, 2009 Report Posted September 23, 2009 Mike... I'm working just now on the driver ... ;)It WILL work fine today.and the curse will be away :D
