grnsky Posted February 1, 2009 Posted February 1, 2009 Hi. I'm not an engineer, so I was wondering if someone could help me...I'm looking at the section of the CORE module components chart on ucapps main page that I've attached a pic of here, and I'm a little confused where in the right two columns there are two values separated by comma.In the "C3, C4" line for example, it says "10uF, 100uF". This seems to suggest: C3 is where you put -> 10uFC4 is where you put -> 100uFHowever, on my board (from the kit from Smash TV) C4 has a circle around it that perfectly suggests that green capacitor that says 10uF. Other pairings make more sense the way I'd read it like C5/C6. The shapes line up with that one.Is this way of reading the chart correct? or does it not go like that? I'd especially love to know which is which for R5/R6 because I really have no intuitive sense for that! :PThank you VERY much!!!!!
Futureman Posted February 1, 2009 Posted February 1, 2009 I'd just follow Smash's site... well, thats what I did anyway for construction of his boards / kits.http://www.avishowtech.com/mbhp/mbhp_coreR4d.htmlRegardsMike
nILS Posted February 1, 2009 Posted February 1, 2009 In the "C3, C4" line for example, it says "10uF, 100uF". This seems to suggest: C3 is where you put -> 10uFC4 is where you put -> 100uFIt doesn't quite ;-) It says 10uF and 100nF. That's a pretty big difference as the 100nF cap is not one of those big, round electrolytic capactitors.
