Digispunk Posted April 4, 2009 Report Posted April 4, 2009 Hi everyonei'm trying to upload/send a new Midibox64 bank/preset using Serge's Midibox64 editor,i've made the patch with all the desired button/pot commands, and saved the sysex file for future reference, now the problem is - how to upload to my midibox?i've tried using the 'send sysex' button and the dialogue box says its sending, but my midibox does not acknowledge the incoming data.does the midibox need to be in a special mode to recieve the dump? if so my problem is that none of the buttons are currently progrmmed to navigate the menu structure.for troubleshooting info - im using MIOS 1.9i have the midi in/out device set properly - tested and checked using Midi OX and also by way of learn commands so i dont think thats the issuei dont have a bankstick attached yetare there any detailed tutorials for uploading banks? i tried using the search terms 'serge / midibox64 editor / upload bank etc and not found one yet. Quote
TK. Posted April 4, 2009 Report Posted April 4, 2009 It's like you are trying to open a .mp3 file on your computer, but no MP3 player is installed...You've to upload the midibox64 application.Best Regards, Thorsten. Quote
Digispunk Posted April 4, 2009 Author Report Posted April 4, 2009 sorry if it wasnt clear - but i have uploaded the midibox application :) all the pots and buttons work, the lcd shows the values etc and when it boots up - so yes MB64 app is installed, and midi monitor app on the computer shows it is sending the correct midi messagesi just dont know the procedure for uploading a bank/patch to the unit with serge's editor, and i cant manually edit the box through hardware because the buttons arent programmed with the menu functions (they are all midi note messages) Quote
Digispunk Posted April 4, 2009 Author Report Posted April 4, 2009 made some progress - decided to start from scratch and reload MIOS - found that the MIDI in port cable was dodgey - so corrected itsuccessfully uploaded MIOS ver.9f to coresuccessfully uploaded Midibox64 app - ver 2.4all pots, buttons, faders etc work, LCD displays all correctly and tested MIDI out with Ableton and it works fine - now back to Serge's MIDI editor - try to upload new bank via sysex and get this reply"MIDI time out! Whats up???".serge editor displays problem/error messages when uploadingsearched and found a similar problem here - http://www.midibox.org/forum/index.php/topic,10877.msg94380.html#msg94380was hoping to find the answer - but it seems that Foona manged to overcome the problem by switching to a new computer and MIDI interface - which is odd as he could upload MIOS/Midibox64 app etc without problem but got the time out error using serge - any ideas besides switching to a new computer and Midi interface? i am using M-Audio UNO midi interfaceafter a short rest, i gave it another go with the same Midi interface etc, strangely the upload from serge to core worked a bit - i say a bit because the dump was registered on the core as successful, and the pots i re-labeled in serge worked, but the buttons didnt, not sure why. anyhow after a few more attempts, it stopped working altogether and went back to the 'midi time out' messagesi have tried adjusting the 'delay between sysex blocks' time but that doesn't help....i will try again tomorrow. Quote
TK. Posted April 5, 2009 Report Posted April 5, 2009 First of all it's important to use the "18f" version which can be found under http://miostools.midibox.org/If SysEx transfers are unstable with this version, it could be related to a Windows driver issue of your MIDI interface (SysEx blocks > 256 bytes not transfered completely). Miditrix helps to overcome this - some informations can be found hereBest Regards, Thorsten. Quote
Digispunk Posted April 5, 2009 Author Report Posted April 5, 2009 thanks, TK,im definitely using the 18f version of Serge's editor, but i will try the Miditrix app to see if it improves sysex handling. Quote
Digispunk Posted April 5, 2009 Author Report Posted April 5, 2009 well, i got some initial success using Miditrix and Mdi yoke,i say initial, since i could upload Pot values without error, but the new button values dont update... need to investigatethanks TK. Quote
Austin73 Posted May 10, 2009 Report Posted May 10, 2009 I'm not really the most informed person on here (honest lo) but I did notice your using a M Auio Uno - I have noticed on other forums Behringer Uno etc that people have had lots of problems with this interface. Is there any chance you can borrow a different interface and try that ?I hope that helps ishAus Quote
bugfight Posted May 11, 2009 Report Posted May 11, 2009 i've been using m-audio uno for midiboxing for a few years (under winxp). the only issue i've had is it doesn't support multiple clients at once.i have not built the midibox64 though.hope that helps... Quote
Austin73 Posted May 11, 2009 Report Posted May 11, 2009 Hi Bug fight I'm sure the interface is very good - I use a 2x2 midisport but like I said I'm sure I have seen issues on a couple of sites - can't remember which maybe Guitar Rig or Behringer Uno.It is worth a try then it can be eliminated and maybe check the cables too. Aus Quote
TK. Posted May 12, 2009 Report Posted May 12, 2009 I used a MIDIsport 2x2 many years w/o issues. But the driver is multi client capable. If M-Audio Uno doesn't support multiple clients, this indicates that a different driver is used which could have bugs.Best Rgards, Thorsten. Quote
stryd_one Posted May 15, 2009 Report Posted May 15, 2009 IIRC, the uno uses the standard USB drivers built into your OS. Quote
