wavewalker Posted August 17, 2009 Posted August 17, 2009 hellothe midibox run with momentary type led buttons (push and keep push =ON , release =OFF)or not "momentary" type (push =on , re-push =off) ? ???thanksww
rosch Posted August 17, 2009 Posted August 17, 2009 hi! you'll find your answers in the DokuWiki parts FAQ:http://www.midibox.org/dokuwiki/doku.php?id=parts_faqand on the wiki page of Wilba's 6582 you'll find also an example with name, manufacturer and part number of a possible switch:MB6582 CS parts list
Janis1279 Posted August 17, 2009 Posted August 17, 2009 the midibox run with momentary type led buttons (push and keep push =ON , release =OFF)or not "momentary" type (push =on , re-push =off) ? ???In the midibox tutorials may be you read about a special feature which will be assigned to the buttons : Toggle value - Send learned value with the first keypress, send zero value with the second keypress.
wavewalker Posted August 17, 2009 Author Posted August 17, 2009 thanks guys ! ! !seen this good pagehttp://www.midibox.org/dokuwiki/doku.php?id=parts_faqonly an info about button with led : if i use momentary button (as suggested )when i push the button the core receive the command and led go on with light,but:when i release the button the command and the led stay in on "status" until i re-push the buttonor go in off ?thanks in advanceww
