woozle Posted September 19, 2009 Report Posted September 19, 2009 I think I've tried every possible wiring configuration, but I'm not getting any output from my pot(s). I've eliminated the AIN module and I'm trying to run a single pot off of j5a. I get no midi output, only resets when I cause a short. I've followed the diagrams here http://www.ucapps.de/mbhp/auaimbctg.pdf with no luck it seems. MIOS studio registers nothing on MIDI, except on resets. Are there any photographs of pots wired up to core revision r4d alone or w/ AIN r4? I'm making no progress. Running latest 64e app.
nILS Posted September 19, 2009 Report Posted September 19, 2009 Try the ain64_din128_dout128_v2b app (less is sometimes more).Your pot (is it ~10k?) most likely has 3 pins (as in the attached pic). A goes to Ground, B goes to the J5 pin and C goes to +5V. If that doesn't work - show some pics!edit: whoops. forgot the pic :-)
Janis1279 Posted September 20, 2009 Report Posted September 20, 2009 Are you corrected the some default values for pots in the setup_midibox16e.asm file :...#define DEFAULT_NUMBER_AIN 0;; you could enable the multiplexers here to test this application; with a MIDIbox64 based hardware; if 0: no multiplexers (a *must* when MF module connected); if 1: use multiplexers#define DEFAULT_ENABLE_AIN_MUX 0...
woozle Posted September 22, 2009 Author Report Posted September 22, 2009 Nope, didn't enable multiplexers. That would be part of my problem, but I can still test pots in unmuxed mode directly on the core without recompiling with this flag set, right? I want to make sure I'm wiring things up correctly before I add in the AIN module.
Janis1279 Posted September 22, 2009 Report Posted September 22, 2009 Nope, didn't enable multiplexers. That would be part of my problem, but I can still test pots in unmuxed mode directly on the core without recompiling with this flag set, right? I want to make sure I'm wiring things up correctly before I add in the AIN module.Are you corrected the some default values for pots in the setup_midibox16e.asm file :...#define DEFAULT_NUMBER_AIN 0;; you could enable the multiplexers here to test this application; with a MIDIbox64 based hardware; if 0: no multiplexers (a *must* when MF module connected); if 1: use multiplexers#define DEFAULT_ENABLE_AIN_MUX 0...in this string:#define DEFAULT_NUMBER_AIN 0edit your pots quantity from 0 up to 8 for unmuxed mode , recompile , and pots will work.
woozle Posted December 10, 2009 Author Report Posted December 10, 2009 in this string: #define DEFAULT_NUMBER_AIN 0 edit your pots quantity from 0 up to 8 for unmuxed mode , recompile , and pots will work. For muxed mode, do I want to specify both the muxed flag and the number of pots or just the muxed flag?
