power supply for opl3?
benuron
A PC PSU is unstabilized. What you really want is a stabilized design.
I have build a psu according to the following the following design: http://www.circuitsonline.net/schakelingen/30/voedingen/78xx-voeding.html
The PCB setup: http://www.uploadarchief.net/files/download/co%2078xx%20voeding%202008.pdf
You can use the design for both the +5V and the -12 and +12 Volt. Or you can combine the -12 and +12 in one design like: http://www.reconnsworld.com/power/multipowersupply.gif
Thnaks for the reply's  ;)
I will use Center Tap Transformer method http://www.midibox.org/dokuwiki/doku.php?id=bipolar_12v_psu
I have some doubts in what transformer should I buy...
This one is 15-0-15v 0.3A
http://www.leiritronica.com/electronica/product_info.php?cPath=7_8&products_id=41297
This is 15-0-15v 1A
http://www.leiritronica.com/electronica/product_info.php?cPath=7_8&products_id=41299
Or a toroidal transformer of 80 VA 2 x 24 V / 2 x 1,67 A
http://www.aquarionet.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=9838&category_id=139&option=com_virtuemart&Itemid=71
Which one is the best to power the opl3 module and maybe later the AOUT module? :)
To power the opl3 module and maybe later the AOUT module(-es), is enough with this 15-0-15v 0.3A transformer.
But to power the Core module from the another transformer with a little lower secondary voltage ~ 7,5 to 10 volts .
Thanks! I will use that 15-0-15v transformer.
To power the core module I already have an 9v wall wart supply. :)
But...I have more questions!sorry  :P
I do the math and the capacitor size is 1410uF so I will use a 2200uF, right?
Any rectifier will do the job?Do I have to had precautions in which I should pick?
What fuse to pick?Fast/slow blow?current?
http://www.midibox.org/forum/index.php?PHPSESSID=8672ceb6daaa67070d21551f269466ce&topic=6735.0
http://www.midibox.org/forum/index.php/topic,13044.msg111261.html#msg111261
  • 2 months later...
Ok!
I've finished the core and opl3 module, moving to the constrution of the psu.
I've more questions... :unsure: On the NorthernLightX schematic after the rectifier, the voltage increase but in the wiki page about bipolar supply's it says that the voltage drops. Anyone can explain?
How much is the power consumption of a full midibox FM? :)
I've more questions... unsure.gif On the NorthernLightX schematic after the rectifier, the voltage increase but in the wiki page about bipolar supply's it says that the voltage drops. Anyone can explain?
http://www.answers.c...e_rectification :
The average and root-mean-square output voltages of an ideal full wave rectifier can be calculated as:
Where:
Vdc,Vav - the average or DC output voltage, Vp - the peak value of half wave, Vrms - the root-mean-square value of output voltage. π = ~ 3.14159 e = ~ 2.71828
Peak loss
An aspect of most rectification is a loss from the peak input voltage to the peak output voltage, caused by the built-in voltage drop across the diodes (around 0.7 V for ordinary silicon p-n-junction diodes and 0.3 V for Schottky diodes). Half-wave rectification and full-wave rectification using two separate secondaries will have a peak voltage loss of one diode drop. Bridge rectification will have a loss of two diode drops. This may represent significant power loss in very low voltage supplies. In addition, the diodes will not conduct below this voltage, so the circuit is only passing current through for a portion of each half-cycle, causing short segments of zero voltage to appear between each "hump".
Regards, Janis
So there is a voltage drop...
Sit a bit confused!
â– Theory of operation
â– The big resistors will dissipate an amount of Volts equal to the amount of Ohm they're rated for, at a current of 1 Ampere. If the current is less than 1A they will dissipate less, but the regulators will be stressed less too, so this is exactly what is wanted. The power out of the mains can be plus or minus 10% of the specification (115V or 230V). Let's assume it is -10%, as it is in my house. So, instead of the 12V the trafo delivers at 230V, it in fact delivers 10,8V (12V - 10%). When rectified and filtered, the voltage becomes 10,8V * 1,41 = about 15,23V. this is perfect for the 7812 and 7912, so far so good.
Where that 10,8v * 1,41 comes from?
Found a site with the answer http://www.kpsec.fre...p.htm#smoothing
If I use a 12v transformer...
The main voltage in my house is 240v so the voltage in the secundary side of transformer would be 12,52v, after the full wave rectifier 11,12v (1,4v loss) and after the smoothing 15,57v good for the 12v regulators, right?
I could be wrong.
But your secondary DC voltage calculations refers to the power supply with not any load at the output!
If you have possibilities to make this similar rectifier + the linear regulator model and to make some simple experiments with loads up to 100 mA, (I think, it's enough for the first time Midibox FM bi-polar power supply), it will give more details for your information.
Regards, Janis
I could be wrong.
Regards, Janis
Yes, my calculations are without load.
I made an order of one transformer with 30va and 2x12v, when it arrives I will experiment.
And here are some pictures with the core running the midimon app and the opl3 module :)
  • 4 months later...
