vcfool Posted November 17, 2009 Posted November 17, 2009 So after a week of trying V3, I updated to V4 and finished the thing. Here's some pictures... Again I used a clear acrylic panel and I made a wood case for it: Rear. The 3'5mm jacks on the left side are the AOUT_NG CV Outs, J5 Gates and Clock/Run outputs: More pictures from the construction can be found on: http://picasaweb.google.com/vcfool/MBSEQ# This thing really rocks! Thanks again to TK, Wilba, SmashTV, fussylizard and everyone else in here. Now I wonder what to do with the ultracore...
Wilba Posted November 17, 2009 Posted November 17, 2009 Awesome work! I love how you've stacked everything under the PCB... nicely done.
fussylizard Posted November 17, 2009 Posted November 17, 2009 Wow, looks fantastic! I also like the "sammich" style board positioning. :-) BTW It looks like the LCD backlights are a bit bright so you might consider increasing the backlight trimpots to 50k per this post: The displays look fantastic with that adjustment, better than my CrystalFontz display on my MB-6582 that I really like. Glad I could play a (very) small part in making your MB-SEQ happen! Regards, C
vcfool Posted November 17, 2009 Author Posted November 17, 2009 Thank you both, P1 is already 50K. P2 is 10K.
ultra Posted November 18, 2009 Posted November 18, 2009 Now I wonder what to do with the ultracore... you could always send it back to me :>
vcfool Posted November 18, 2009 Author Posted November 18, 2009 you could always send it back to me :> HAHAHA! This is not what I meant... I was more thinking to use it with another application. I see there's a MIDI Router I could build, but honestly, I don't think I am needing it at the moment. Any other option?
HUROLURA Posted November 20, 2009 Posted November 20, 2009 Where did you get the encoder/buttons PCB ? Homemade ???
vcfool Posted November 21, 2009 Author Posted November 21, 2009 Where did you get the encoder/buttons PCB ? Homemade ??? That is Wilba's CS PCB. Take a look here:
vcfool Posted February 22, 2010 Author Posted February 22, 2010 Last week I added the IIC_MIDI modules to my MB-SEQ V4. The circuit. 4x MBHP_IIC_MIDI ("OUT Only" version). No LEDs, no J3: The insides. Installed and connected: The back. I used this D-SUB 9 for the 4 MIDI OUTs because it was the easier way to modify the back panel: Thanks again to everyone!
