Awesome... all put together.
Passed all tests well.
Assembled and uploaded "Sammich_SID.hex"
Boots up fine, but I can't navigate at all.. The only buttons that work (Menu,Shift,up, Down) all seem to bring up a "SID3 not available (CAn bus Errors" message
I've check the orientation of the resistor arrays (Dots line up with dots on PCB)
Any Ideas?
Regards
Mike
hmmm... it's as if the button's are mixed up..
F3 is down, S5 top button is up.
S4 is is the first selection, S3 is 2nd, S2 is 3rd, S1 is 4th, F1 is first.
Plugging away..
Regards
Mike
Someone broked the preconfigured .asm? Uh-oh, I'll look into it right away. Actually, I should have Wilba look into it :D
Yes, you should :D
Futureman, you're probably uploading the MB-SID RC33 release instead of the setup_sammich_sid.hex that I emailed out to everyone.
TK had added the setup_sammich_sid.asm at that point, but hadn't integrated the right configuration for DIN/DOUT etc.
Awesome!
Sorted, uploaded, playing as I type.
I'll post pics tomorrow.
Brilliant and easy to assemble project.. no surprises, easy to follow documention, and looks like a sexy brick!
Regards
Mike
