Nat Posted July 31, 2003 Report Posted July 31, 2003 Hello, I plan to mount my swtiches and leds on vectorboard and I'd like to know what's the best way to do it, like on this photo :Would it be possible to have a photo of the other side of the board ? Would help a lot,Thanks,Nat
Steven_C Posted August 3, 2003 Report Posted August 3, 2003 this looks like a vgectorboard made by TK, from before he had access to PCB's. Have a look at my midibox photos in the gallery, or also in the midibox of the week thread, to see how I mounted the LED's and buttons, I ran wires straight from the back of the vectorboard to header pins on the PCB'sgood luck, from Steve ;)
Nat Posted August 3, 2003 Author Report Posted August 3, 2003 But how does the components stay on the board ? Only with the wire or with some glue ?Thanks,Nat
TK. Posted August 3, 2003 Report Posted August 3, 2003 They are soldered to the copper pads on the opposite side:Best Regards, Thorsten.
Nat Posted August 4, 2003 Author Report Posted August 4, 2003 Thanks :)The vector board at my store doesn't have any solder pads that's why I didn't get it ..
Steven_C Posted August 7, 2003 Report Posted August 7, 2003 ;) he he, now you get it ;)Thorsten, what is that monster you are building?? Is it like one of the new mackie control for plugins?
gillesdeshays Posted August 7, 2003 Report Posted August 7, 2003 Hi Nat !a tip for you :http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=tips;action=display;num=1060043167 8)
Nat Posted August 7, 2003 Author Report Posted August 7, 2003 Thanks ;) I get it now, I'll just have to find some vector board of the good size with solderpad.... the only stuff I see hear is without pads or too small :(
Steven_C Posted August 8, 2003 Report Posted August 8, 2003 Nat, Let me know if you can't find anything local, I could post you some, should be able to post pieces in an envelope to you!
Nat Posted August 8, 2003 Author Report Posted August 8, 2003 Cool thanks, i'll try to find some here but if I'm in desperate need of it i'll ask you :)
Guest den_Juin Posted August 8, 2003 Report Posted August 8, 2003 What's the cost of these things at your local store?Here it is 5euro for 160x120... that's pretty expensive if you want to mount all your pots and encoders this way.
Nat Posted August 8, 2003 Author Report Posted August 8, 2003 I don't know for steve but the stuff here is around 1$ for 20cm*20cm. Problem is that I can't find anything larger than that :(
Guest PHX Posted August 8, 2003 Report Posted August 8, 2003 Hi Nat,Are you in the US ? If that's the case, could you tell me where are you finding such cheap vector board ?Tks,Richard
Nat Posted August 8, 2003 Author Report Posted August 8, 2003 I'm in Canada, it,s a store named addisonwww.addison-electronique.com
Steven_C Posted August 9, 2003 Report Posted August 9, 2003 very cheap, us aussies are definately getting ripped off down here... my vectorboard to mount buttons on LC cost around $30 Australian, from Dick Smith!
nILS Posted August 10, 2003 Report Posted August 10, 2003 Reichelt /Germany) charges:50x100mm : 0.61 EUR100x100mm : 1.10 EUR200x100mm : 2.05 EUR500X100mm : 5.00 EUR
