Where can I get the exact specs for a MB-6582 frontpanel? My friend is into metal work, and we might take a shot at making one ourselves.
I found the link to the .fpd, but I have a Mac, so I can't install Frontpanel Designer.
Hi Pingosimon
Here is a link to the MB6582-panel wiki page
http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582_panels
At the very bottom you'll find a .zip-file containing frontpanel-files in .dxf format. This is a common format for both CNC machinery and CAD/3D software. It is very likely that you can find some software for the Mac to open the files - a quick guess would be InkScape, afaik it opens dxf files, it's free, and there is a Mac version :D maybe not the best solution, but it might just do the trick.
Cool thanks!
Before using them, please check the dimensions match those in the FPD files
Sooo, someone want to give me the length and width of the entire panel? If the machine's software changes the .dxf, it'll do it by a scale, right?
  • 3 weeks later...
Yep...he took it to work, uploaded the .dxf to the machine, and it told him the total panel size would be about 200 ft :tongue:
Thanks, Phil!
Can someone give me the rear panel measurements? I don't have a Pactec case yet, but I'd like my panels to be compatible with one.
You are quite correct (it was a deliberate mistake to make sure you are paying attention !!!)
hmm, I hope not! I'm honestly new to this, and would rather learn the cheaper way, as opposed to the "waste money ordering the wrong panel" way.
And you just learned a valueable (and free) lesson: People make mistakes, double check! :)
No it was a genuine mistake.... nILS is right though, it is always worth double checking things. As one of my college lecturers always used to tell me "measure twice, cut once!"
Phil
