djdeeg Posted January 28, 2010 Posted January 28, 2010 Hello. First greetings from Croatia and i must say that http://ucapps.de/ is amazing site for midi freaks. I work on my midi controller for Traktor Pro and everything is set but because i am not programmer i need help with firmware. I need something like this "MIDIbox16e V1.004 - supports up to 16 rotary encoders, 16 LED rings, 64 buttons, 64 LEDs." but without LED rings and for PIC 18F452. Pleae help me because i was try all firmwares from site but this is what i need........ Thanx Aleksandar
Janis1279 Posted January 28, 2010 Posted January 28, 2010 (edited) More similar to MIDIbox16e V1.004 looks Midibox64E file: http://ucapps.de/mio...ox64e_v2_2d.zip Edited January 28, 2010 by Janis1279
djdeeg Posted January 28, 2010 Author Posted January 28, 2010 I try this but is not what i need because there is only LED rings and not LED-s with buttons and encoders, but thanx for help....
seppoman Posted January 29, 2010 Posted January 29, 2010 (edited) uhm, Janis is right - you want a mb64e, that's exactly a "mb16e but for 18F452". Don't know what you mean about the LED rings - nobody forces you to build everything the firmware is capable of. If you don't want them, just leave them out. you can also setup the pin configuration etc. yourself, you probably won't find a precompiled and configured firmware to download that's exactly matching your personal Midibox. BTW, you should also take a look at MTE's Traktorizer project (listed under "User Projects"). S Edited January 29, 2010 by seppoman
djdeeg Posted January 31, 2010 Author Posted January 31, 2010 (edited) seppoman i know that MIDIbox64Eis what i need but how to avoid first 4 shift registers (first DOUTX module) because in firmware they are for LED rings and i don't need it. So i need to get two DOUTX modules and connect leds only on second module? I use "setup_midibox16e.hex" and my configuration is like this: Edited January 31, 2010 by djdeeg
Janis1279 Posted January 31, 2010 Posted January 31, 2010 (edited) Are you read this page, too? http://www.midibox.o...n_dout_pin_list As i understand , i found some missing hex values here. At the 4-column from the left from the beginning right values are: "Pin hex number (sw) " 0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 from this raw the another hex values are ok Regards, Janis Edited January 31, 2010 by Janis1279
djdeeg Posted January 31, 2010 Author Posted January 31, 2010 (edited) Just for test i connected led on first 3 pin on DOUTX. With "setup_midibox64e.hex" everything works ok, when i press button led going on. With "setup_midibox16e.hex" leds are always on and in editor when i change shift rgisters to button nothing happens. Edited January 31, 2010 by djdeeg
seppoman Posted January 31, 2010 Posted January 31, 2010 (edited) you can also setup the pin configuration etc. yourself, you probably won't find a precompiled and configured firmware to download that's exactly matching your personal Midibox. please read the readme.txt and the asm sourcecode (in the mb64e package) on how to adapt pin configurations to your needs. S Edited January 31, 2010 by seppoman
djdeeg Posted January 31, 2010 Author Posted January 31, 2010 please read the readme.txt and the asm sourcecode (in the mb64e package) on how to adapt pin configurations to your needs. S Once again i am NOT programmer........... This writes in my first post. Please if is someone who can change "setup_midibox16e.hex" that first DOUTX are for LED's and NOT for LED rings. My midi box is almost done and this is all what i need to finished this project so if is someone who want to help me ???? Thanx
Janis1279 Posted January 31, 2010 Posted January 31, 2010 (edited) I am not a programmer, too But you read and read and ... setup_midibox16e.asm setup_midibox16e.hex Regards, Janis Edited January 31, 2010 by Janis1279
djdeeg Posted February 1, 2010 Author Posted February 1, 2010 I am not a programmer, too But you read and read and ... I see that you are smarter than me because that please if you can change this for me? If not thanx anyway maybe will be somebody on this forum who wanna help me in practice.
djdeeg Posted February 24, 2010 Author Posted February 24, 2010 Is anybody here who can help me??? I realy need help................
nILS Posted February 24, 2010 Posted February 24, 2010 All the questions you have asked have been answered. At least you'd need to tell us what exactly your problem is after following the advice you've been given.
djdeeg Posted February 24, 2010 Author Posted February 24, 2010 Hello. I need somebody who can change setup_midibox16e.hex for me. I don't need led rings on first 4 shift registers but only led's. I try to make some changes but with no success. Please if somebody wanna to do that. I was build my controller and this is what i need for finishing it. Thanx
nILS Posted February 24, 2010 Posted February 24, 2010 What exactly have you changed and how did it not succeed?
TK. Posted February 24, 2010 Posted February 24, 2010 Hi, I need something like this "MIDIbox16e V1.004 - supports up to 16 rotary encoders, 16 LED rings, 64 buttons, 64 LEDs." but without LED rings and for PIC 18F452. Pleae help me because i was try all firmwares from site but this is what i need........ I created a special .asm file for your configuration here: http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox64e%2Fsetup_midibox16e_without_ledrings.asm It will be automatically part of the next release package. Attached you will find the prebuilt .hex file of the current release. Best Regards, Thorsten.setup_midibox16e_without_ledrings.hex
TK. Posted February 24, 2010 Posted February 24, 2010 P.S.: note that I updated the binary with improved pinning for your special case - I hope that you like it, because I won't create another configuration
djdeeg Posted February 24, 2010 Author Posted February 24, 2010 TK thanx alooooooooooooooooooooooot. I am on work now and first thing when i wake up will be finishing my controller.
