MB6582 PSU
Shuriken
As my MB6582 is nearing completion, i need to start building a decent PSU.
At first i thought about using Northernligthx design but there are some flaws. I spoke to him and he told me his design isn't working well at the moment.
So i decided to make my own design taking his as inspiration. I want to use a 2 x 12V Transformer:
On another electronics forum i was warned about latch-up. So i want to change the design and add a latchup protection. It's supposed to be done by adding some diodes. But i am not sure how.
So i would be helped if anybody could tell me how.
No, i haven't build it. I decided against it actually. The two big resistors are basically giving off 12W of heat under full use. Since i am not going to be using 6581 SIDS, i wont need 12 Volts.
So i decided i might as well use a C64-II PSU. I did almost do it though but then the resistor were out of stock at Reichelt.
Edited by Shuriken
