Confused Re 2xLC
Lu Taska
So I've spent some time doing some reading, and I beleive that in the coming weeks I'll be ready to start my project.
The plan is to have a 16channel motor fader board plus one master fader. By my understanding and calculations I will need the following:
3x PIC18F452 cores - 8 faders max on each core, therefore I need three. Right?
4x 2x40 character LCDs
6x DOUTX4s
3x Motorfaders (right? 8+8+1?)
Here is where I am getting confused. I've crudely worked out that I need 6 DINx4s with the following logic:
Since I only need a single master section, a 2 LC design doesn't need twice the buttons that 2 single LCs would have.
And, as aach extra channel contributes four switches, an extra eight channels will contribute 32 switches.
Therefore i should only need an extra two DINx4s right?
Also, do these three cores connect individually or are they chained somehow? And on extension, how many LTCs will i need? One or three?
Thanks for your help. I'll keep looking over Axel's posts while I wait for replies :P.
Link to comment
Share on other sites
Hi Lu Taska
Yes, for your Master Fader, you need an additional core - Do you really need a Master? - Think about it.
Regarding the MF-Boards I would suggest, that you take 2 and the single Master Fader you build just partially on a stripboard.
Regarding the DIN/DOUT boards you see it correct but I don't feel for counting it through.
Regarding the connection of the units, it depends on your host soft. In Sequoia I would connect the master-unit as an independent unit on its own midi port. If you want to connect it together with an 8-fader unit onto one port and handle it as the "master"-controller, you probably have to make use of MidiBox-Link.
About how many LTCs - Go for one GM5
Greets, Roger
Link to comment
Hi Lu Taska
Greets, Roger
I am also busy with a project like this & will need 3 cores for the faders.
If I have this correct, to connect all cores with my computer (I use ProTools on a MAC), I will need for each core a seperate MIDI port.
That means 6 cables, 3xIN and 3xOUT.
Is that correct?
thx
Edited by SNG
Link to comment
That means 6 cables, 2xIN and 2xOUT.
... what now? :rolleyes:
The answer you see in my previous post above:
"Regarding the connection of the units, it depends on your host soft. In Sequoia I would connect the master-unit as an independent unit on its own midi port. If you want to connect it together with an 8-fader unit onto one port and handle it as the "master"-controller, you probably have to make use of MidiBox-Link."
Greets, Roger
Link to comment
Which GM5 will I need?
The 5/5 or the 1/1?
the 5/5 as you use 3 cores and need at least 3 MIDI connections...
good to have 2 reserve for later expansions.... or you can use the 4th port for the master fader as suggested by Roger :)
I will not use a separate master fader as each fader on my master panel can function as the master fader... we all have our own preferences :))))
I have just calculated that I need for all my VU LED panels an separate core and 4xDOUT4.... is it possible to use a link or LTC to guide the signal through an another core...???
Link to comment
The 5/5 or the 1/1?
The gm5 (which is the fun little IC) is always a 5/5. I think you're referring to the PCB: single IO PCB with the possibility to extend (which is what TK sells) or the gm5x5x5 (which is what I sell).
Link to comment
How can I get this gm5x5x5 pcb? Is it supplied with the GM5 chip?
Link to comment
Guest
Reply to this topic...
