Aliã Bianco Posted August 3, 2010 Posted August 3, 2010 Sorry if my questtion is stupid, but i read http://www.midibox.org/dokuwiki/doku.php?id=windows_toolchain_quickstart ,search forum and google but... wen i try to compile my project, this happens: make: *** C:\MIOS\Mios_Base: Invalid request code. Stop. What is wrong in Mios_Base folder??? PS: MIOS_PATH and MIOS_BIN_PATH is ok SDCC ok MSYS ok GPUtils ok PATH ok (C:\MIOS;C:\MSYS\1.0\bin;C:\Arquivos de programas\gputils\bin;C:\Arquivos de programas\SDCC\bin) my folder project: c:\mios\vmx200 Thanks!
nILS Posted August 3, 2010 Posted August 3, 2010 That sounds like there's some stuff missing or can't be found. Since it's fairly hard to guess what that may be please do the following: 1) Open a command prompt like you usually do, and do what you do to get to the point where you try to make the app 2) Type "set mios" and post the results here 3) Type "make --version" and post the results here Then we'll take it from there :)
Aliã Bianco Posted August 3, 2010 Author Posted August 3, 2010 (edited) Microsoft Windows XP [versão 5.1.2600] © Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Aliã>cd c:\mios\vmx200 C:\MIOS\vmx200>make make: *** C:\MIOS\Mios_Base: Invalid request code. Stop. C:\MIOS\vmx200>set mios MIOS_BIN_PATH=C:\MIOS\Mios_Base\bin MIOS_PATH=C:\MIOS\Mios_Base C:\MIOS\vmx200>make --version GNU Make 3.81 Copyright © 2006 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. This program built for i686-pc-msys C:\MIOS\vmx200> strange... thanks again. Edited: I dont have mingw installed, i need it?? where i can find? and what version? because in wiki mingw is installed, look: C:\MSYS\1.0\bin;C:\Program Files\gputils\bin;C:\Program Files\SDCC\bin;C:\MinGW\bin;C:\Program[bLABLABLA] I reinstall all again and reupload mios_base_v1_1... I see some strange stuff in post install of my sys, but is about mingw, and i dont have it, but... This is a post install process that will try to normalize between your MinGW install if any as well as your previous MSYS installs if any. I don't have any traps as aborts will not hurt anything. Do you wish to continue with the post install? [yn ] y Do you have MinGW installed? [yn ] n When you install MinGW I suggest you install it to C:/mingw (replace C: with the drive of your choice). Then create an /etc/fstab file with a line that has a value similar to: C:/mingw /mingw Press ENTER to continue Normalizing your MSYS environment. You have script /bin/awk You have script /bin/cmd You have script /bin/echo You have script /bin/egrep You have script /bin/fgrep You have script /bin/printf You have script /bin/pwd MinGW-1.1 has a version of make.exe within it's bin/ directory. Please be sure to rename this file to mingw32-make.exe once youve echo installed MinGW-1.1 because it\s very deficient in function. Press ENTER to continue. Edited August 3, 2010 by Aliã Bianco
bassline Posted December 30, 2010 Posted December 30, 2010 Hey! I have a MIDIbox SID synth, working. How can i configure the buttons, encoders and the lcd display? I have 8 rotary encoder+6 button and a 4X20 lcd display. The PIC is a 18F452. "midibox_sid_v1_7303e" is ok. Which file and how? How to reprogrammed and burn the device with the new firmware? Thanks! Best:)
TK. Posted December 30, 2010 Posted December 30, 2010 Relevant for MBSID V1 (not MBSID V2!): - setup_*.asm (the setup file you are using) - src/mios_tables.inc - src/cs_menu_io_tables.inc - src/cs_menu_enc_table.inc There are some comments in these files which you have to read to understand the configuration options. Once the firmware has been recompiled, just upload the resulting .hex file via MIDI like you did before. Best Regards, Thorsten.
bassline Posted December 30, 2010 Posted December 30, 2010 (edited) Hallo Klose! Danke für die Beihilfe! Das wird meine erste midibox projekt:-) Beste Grüsse!;-) Edited December 30, 2010 by nILS Don't fullquote posts with pics unless you actually respond to them, please.
