the19thbear Posted August 24, 2010 Posted August 24, 2010 HI. where is the cheapest place to get led rings with or without encoders? (like the bcf2000) thanks!
Phattline Posted August 25, 2010 Posted August 25, 2010 you could make 2Boards... the buttom board - with the encoder on it and its Shiftregisters and resistors... and a top board with the Leds on it and its Shiftregisters and Resistors...---and then drill a hole in the LED boards, for the Encoder shaft... this make the DIY Board-design (if single sided is the only way...) and so on much easier... The BCRs are SMD LEDs with some transparent Plastik-shafts on it... plastic waste... when you use 1mm standard LEDs and drill holes for that in your Front-Panel - Then this looks the same way...
