I have been trying out a few tutorial programs and the SRIO example. Everything was working OK but now I have a consistent error.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
E:\Documents and Settings\robin>cd  mios32
The system cannot find the path specified.
E:\Documents and Settings\robin>cd\
E:\>cd mios32
E:\MIOS32>cd trunk
E:\MIOS32\trunk>cd apps
E:\MIOS32\trunk\apps>cd examples
E:\MIOS32\trunk\apps\examples>cd srio
E:\MIOS32\trunk\apps\examples\srio>make
E:\mios32\trunk/include/makefile/common.mk:123: *** multiple target patterns.  S
top.
What would cause the multiple target patterns referred to ?
I'm starting to look into mios32 but I'm getting the same error as Robin.
Seems like the link is dead.
Any clue?
Cheers!
Well, seems like setting
MIOS32_PATH=/c/midibox/mios32
MIOS32_BIN_PATH=/c/midibox/mios32/bin
instead of
MIOS32_PATH=c:\midibox\mios32
MIOS32_BIN_PATH=c:\midibox\mios32\bin
makes it to work :)
That link will only work for members with specific access to the Programmers Lounge, other users will get an error.
hpmk, you have found the solution anyway but if you plan to do some development, i'm sure TK will grant you access to the lounge.
Cheers
Phil
Waiting for my core32 pcb+kit actually, but yes I plan to develop some application.
It would be great to have access there so we can share knowledge.
Love.
Access to programmers lounge should work now - have fun!
  • 3 weeks later...
Posted (edited)
mmm...for me the link doesn´t work at all... getting "An Error occurred" and "[#10342] We could not determine which forum this topic is in. "
just stumbled over this topic cause i got the same "multiple target patterns. stop." message when trying to compile via make.
any hints?
Edited by nuke
The link points towards the Programmer's Lounge, which you don't have access to (ask TK about getting access).
Meanwhile here's the solution proposed there by TK:
Ok, today I tried this with my office PC, and can confirm that I see the same errors.
The <drive>: and backslashes cause the issue.
If you look into the project_out directory (where binaries will be generated), you will find a "mios32trunk" directory, but the intended name was "mios32/trunk" (derived from "mios32\trunk)
Solution:
specify MIOS32_PATH in Unix style.
E.g., write:
set MIOS32_PATH=/C/mios32/trunk
[/code]
if MIOS32 repository is located at your C: drive
I hope that this will work for every DOS/Windows user - because once you noticed how fast code will be recompiled after changes in source files, you don't want to miss this feature anymore!
ahh i see ...ok
hey the new unix style PATH works...now there´s something going...getting closer now
thnx for that nils...
but got a new message:
C:\PIC\trunk\apps\sequencers\midibox_seq_v4>make
rm -f project.hex
c:/program files/codesourcery/sourcery g++ lite/bin/../lib/gcc/arm-none-eabi/4.4.1/../../../../arm-none-eabi/bin/ld.exe:
c:/PIC/trunk/apps/sequencers/midibox_seq_v4/project.elf section `._usrstack' will not fit in region `RAM'
region `RAM' overflowed by 112 bytes
collect2: ld returned 1 exit status
make: *** [/c/PIC/trunk/apps/sequencers/midibox_seq_v4/project.elf] Error 1
mmm...somethings not quite right i think
these are my paths for info:
C:\Program Files\gputils\bin;C:\Program Files\SDCC\bin;C:\PERL\bin\;C:\Program Files\CodeSourcery\Sourcery G++ Lite\bin
and my additional system variables:
MIOS32_BIN_PATH=/C/pic/trunk/bin
MIOS32_BOARD=MBHP_CORE_STM32
MIOS32_FAMILY=STM32F10x
MIOS32_GCC_PREFIX=arm-none-eabi
MIOS32_LCD=clcd
MIOS32_PATH=/C/pic/trunk
MIOS32_PROCESSOR=STM32F103RE
did i miss something??
That's not your fault and an issue that's either already resolved (update your sources) or being fixed atm.
ok..thnx...
updated my sources...didn´t change anything...guess i´ll have to wait then... ;)
What version of the CodeSourcery toolchain are you using?
It looks like the version you are using is based on gcc 4.4.1 so I suspect it is the latest 2010q1-188 release which uses Newlib 1.17.
Over the last few days, TK and I have been "playing" with various gcc/newlib combinations in an attempt to find the perfect combination which works on all platforms. This is taking quite a long time as each change requires a 30 minute rebuild of the toolchain :)
It appears that later versions of Newlib are compiling to larger binaries and as SEQv4 almost fills the RAM of the current CORE32, our current thought is that an older version of Newlib may be better as it generates smaller code and most of the enhancements are irrelevant to MIDIbox anyway!
If you are "desperate" to recompile, I suggest you try the CodeSourcery 2008q3-66 release which uses Newlb 1.16. It is available here
Cheers
Phil
  • 1 year later...
Hey,
I have tried to compile SeqV4 and that didn't work because of an overflow.
I then downloaded the other version of the CodeSourcery, using the link Philetaylor put in his msg.
But there is still an overflow, at the end of trying to compile, I get:
Creating object file for osc_client.c
Creating object file for mini_cpp.cpp
Creating object file for freertos_heap.cpp
d:/mios32_tools/bin/../lib/gcc/arm-none-eabi/4.3.2/../../../../arm-none-eabi/bin
/ld.exe: project_build/project.elf section ._usrstack will not fit in region RAM
/ld.exe: region RAM overflowed by 56 bytes
make: *** [project_build/project.elf] Error 1
Does anybody know how I can fix this?
Cheers
Jef
You can't fix this, but I can do this for you ;-)
The linker error was related to one of the last changes in mios32/LPC17xx/mios32_uart.c, which is fixed now.
Please update the repository and compile again with the original MIOS32 tool chain (don't use the Code Sourcery package mentioned by Phil, because it will cause other problems - you have to use exactly the same version like me for a stable build!)
