humboldt Posted January 29, 2011 Report Posted January 29, 2011 (edited) So I finished my Sammich and alot of things work. I was able to upload the application. Some formatting of banksticks happened. Uploaded patch presets. All my buttons and knobs work. My main problem is that one of the audio outputs is almost silent. If I really crank up my amp to the max I can hear it, but Im almost suspecting this is bleed from the other audio channel. On the display for the SID's it says "sid 1***", does this mean only one of my sid chips is active? Also I should have five banks right? A, B, C and D seem fine when when I go to E it says "no bankstick". Would IC10 be bank E? When I get a chance Im going to have a good look my my soldering and take some pics to post here. Are there any other preliminary tests I should try? Edited January 29, 2011 by humboldt
nILS Posted January 29, 2011 Report Posted January 29, 2011 On the display for the SID's it says "sid 1***" No. It means there's one of four cores, which is correct. Also I should have five banks right? A, B, C and D seem fine when when I go to E it says "no bankstick". No. You have 4 banks for patches (A-D) and one bank for Ensembles (H).
nebula Posted January 29, 2011 Report Posted January 29, 2011 one of the audio outputs is almost silent. If I really crank up my amp to the max I can hear it, but Im almost suspecting this is bleed from the other audio channel. On the display for the SID's it says "sid 1***", does this mean only one of my sid chips is active? When I get a chance Im going to have a good look my my soldering and take some pics to post here. Are there any other preliminary tests I should try? Each audio channel comes from one SID ... you could try swapping them to rule out a faulty SID.
humboldt Posted January 29, 2011 Author Report Posted January 29, 2011 Ill try switching the SID's then, I suspect one of them is shot :( At least it seems like my bank sticks are all good.
nILS Posted January 29, 2011 Report Posted January 29, 2011 Since you haven't mentioned it - are you using a cable with stereo plug? What SIDs are you using?
humboldt Posted January 29, 2011 Author Report Posted January 29, 2011 So I switched the SID's around and no matter what position my SID is in the same jack remains really quiet. So thankfully at least it appears my SID's are good. Ill post some pics tomorrow when I get a chance. Maybe some of the expert eyes around here will spot something :)
humboldt Posted January 29, 2011 Author Report Posted January 29, 2011 Since you haven't mentioned it - are you using a cable with stereo plug? What SIDs are you using? Im using mono cables into my Yamaha MR816 interface. I have 6581 SID's.
nILS Posted January 29, 2011 Report Posted January 29, 2011 Well that explains it. There's only one audio output socket and that's stereo. The other socket is an audio in (also stereo).
humboldt Posted January 29, 2011 Author Report Posted January 29, 2011 Well that explains it. There's only one audio output socket and that's stereo. The other socket is an audio in (also stereo). :frantics: Eureka! Yep that was the problem. Luckily I have a stereo to mono 'Y' cable to test it. Simple case of user error, its always the simple things that get me... I guess my sammich is fully operational, it sounds awsome! Thanks so much for the help. I HAZ SAMMICH!
humboldt Posted January 30, 2011 Author Report Posted January 30, 2011 And now after putting the case completely together, I notice the jacks clearly marked as IN and OUT... oh well :blush:
Wilba Posted January 30, 2011 Report Posted January 30, 2011 :frantics: You're not the first to make that mistake.
