grizz Posted June 4, 2011 Posted June 4, 2011 Soooooooooo... one of my expensive pretty optrex display seems to died. More specifically the backlight seems dead. It is on my MB-SEQ V4, so I switched the two displays around and it isn't the core. Has anyone had problems with these dieing? Are there common causes? I don't want to spend another $40 to have another one die too. I also just noticed that the other display's backlight is dimmer on the left half of the display... I'm going to sit down and test the 5v pins on the LCD jumpers on the core32 later, but maybe someone has thoughts or knowledge about why this would happen... other than the displays simply failing of there own accord... Cheers, Alex
latigid on Posted June 4, 2011 Posted June 4, 2011 Soooooooooo... one of my expensive pretty optrex display seems to died. More specifically the backlight seems dead. It is on my MB-SEQ V4, so I switched the two displays around and it isn't the core. Has anyone had problems with these dieing? Are there common causes? I don't want to spend another $40 to have another one die too. I also just noticed that the other display's backlight is dimmer on the left half of the display... I'm going to sit down and test the 5v pins on the LCD jumpers on the core32 later, but maybe someone has thoughts or knowledge about why this would happen... other than the displays simply failing of there own accord... Cheers, Alex Hi, if you managed to short the backlight to ground, that would definitely do some damage. Is it something which happened while you were working on it? Or was it of its own accord?
Altitude Posted June 5, 2011 Posted June 5, 2011 miswiring one is instant death, the backlight LEDs blow immediately
grizz Posted June 5, 2011 Author Posted June 5, 2011 Its been in use for almost a year... it gets moved around a lot from studio to practice and to shows, but I definitely wired it correctly... I know cause I've blown them before :unsure: miswiring one is instant death, the backlight LEDs blow immediately
grizz Posted June 5, 2011 Author Posted June 5, 2011 God damn the other LCD just died... :angry: Everything else works totally fine... wtf???? I'm leaving it on for a bit and monitoring the 5V pin on one of the LCD headers to see if it fluctuates at all... Can someone tell me how to test the backlight pins properly? Thanks alex Its been in use for almost a year... it gets moved around a lot from studio to practice and to shows, but I definitely wired it correctly... I know cause I've blown them before :unsure:
