Posted (edited)
I have completed my MB6582 Base PCB and I did some voltage checks (I went for option B, the original C64 power supply). I haven't installed any IC's so far !
What you can not see on the first picture are the following checks:
J3 (5V) -> 5,33 V
J25 (9-11V) -> 14,28 V -> is this still ok ?
C12 (9V) -> 8,97 V
I made a mistake in the beginning when I checked J25. Unfortunately I slipped off with the contact and created a short on J25 (for a very short moment). After this I check all the points above with the result:
5 V check points -> 5,33 V
9 V check points -> 8,98 V (regarding the SID's: depending on the jumper - I have tested both positions, 9V and 12V)
12 V check points -> 11,82 V (regarding the SID's: depending on the jumper - I have tested both positions, 9V and 12V)
I wonder if I have damaged the two big capacitors close to the voltage regulators ? I mean the measurements look quite ok, apart from the J25 which has 14,28 instead of 11 V. Do you think I can carry on with the board, or do I need to exchange the capacitors or the voltage regulators ?
Your advise is much appreciated !
Cheers
orange
Edited by orange_hand
Posted (edited)
J3 (5V) -> 5,33 V
C12 (9V) -> 8,97 V
Cheers
orange
14,28V on J25 pins instead of 11 V is ok ! This voltage is formed from : Your PSU ~9V out - bridge rectifier - filter electrolytic capacitor - voltage on J25
The other voltages look right, too.
Regards ,
Janis
Edited by Janis1279
