Installing ICs question, sammichSID *FIXED*
bhc303
Hi I am in the final stages of finishing my sammichSID build, I am up to installing the Ic's.
The build guide reads,
"I recommend installing the “Bankstick†ICs (IC6, IC7, IC8, IC9, IC10) and the SIDs (IC1L, IC1R) after fully completing both PCBs, uploading MIDIbox SID firmware and having a fully working control surface. This allows you to watch the formatting of the Banksticks by the MIDIbox SID firmware."
So do I upload the firmware then install ICs (IC6, IC7, IC8, IC9, IC10) and the SIDs (IC1L, IC1R)?
When do I install ICs IC1, IC2, IC3, IC4? I seem to have missed this part...
Cheers
1. Complete the voltage tests for both boards
2. Disconnect power
3. Insert IC1, IC2L, IC3L, & IC3 into the Base PCB
4. Insert IC1, IC2, IC3, & IC4 into Control Surface PCB
5. Reassemble
6. Fire up MIOS Studio
7. Power on the sammich
8. Make sure MIOS and sammich are properly hollerin' at each other
9. Upload the latest sammichSID hex
10. Wait for the sammich to reboot
11. Make sure the fancy knob and buttons are behaving appropriately
12. Disconnect power
13. Insert Banksticks (IC6, IC7, IC8, IC9, IC10)
14. Power on the device
15. Watch in amazement as the banksticks are formatted
16. Load the default patches via MIOS Studio
17. Power down the sammich
18. Install your SIDs with the appropriate jumpers and capacitors
19. Power that MF'er up
20. Check for smoke/fire
21. Perform shredding tunes
22. Create killer patches
23. Record album
24. Get rich
25. Marry supermodel
26. Make more killer records
27. Grow weary of supermodel wife/husband
28. Make poorly executed and ill-advised break-up album
29. Alienate your former fans
30. Take a swing at a reporter that calls you a sell-out and a has-been
31. Retreat from public life
32. Return 6 years later with amazing new album and smoking hot collection of girlfriends/boyfriends
33. Die as a legend in your chosen genre atop a pile of cash
34. Be an icon for generations of musicians to come
I think that's it.
