yodabe Posted September 8, 2011 Posted September 8, 2011 (edited) hi all i build a midibox sid on a home made pcb but a lot of my encoder work on the wrong way i have inverted the sr pin on eagle without paying attention -( when i turn the encoder clockwise it decrease the value that's possible to modify the direction of work an encoder in sid app ? best regards yoda http://www.youtube.com/watch?v=E0QNuXENkQw Edited September 8, 2011 by yodabe
technobreath Posted September 8, 2011 Posted September 8, 2011 Is it possible for u to just cut the tracks and invert the pinning by solder some wires and fix the problem that way? Then u not need to worry about any sw changes...?
TK. Posted September 8, 2011 Posted September 8, 2011 Yes, this is possible by inversing the incrementer in main.inc: ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when an encoder has been moved ;; Input: ;; o Encoder number in WREG and MIOS_PARAMETER1 ;; o signed incrementer value in MIOS_PARAMETER2: ;; - is positive when encoder has been turned clockwise ;; - is negative when encoder has been turned counter clockwise ;; -------------------------------------------------------------------------- USER_ENC_NotifyChange comf MIOS_PARAMETER2, F ; inverse incrementer ... [/code] Best Regards, Thorsten.
yodabe Posted September 8, 2011 Author Posted September 8, 2011 thx Thorsten thats work for all encoder but how to for only 8 encoder on 12 ? 4 work normally thx best regards Pascal Yes, this is possible by inversing the incrementer in main.inc: ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when an encoder has been moved ;; Input: ;; o Encoder number in WREG and MIOS_PARAMETER1 ;; o signed incrementer value in MIOS_PARAMETER2: ;; - is positive when encoder has been turned clockwise ;; - is negative when encoder has been turned counter clockwise ;; -------------------------------------------------------------------------- USER_ENC_NotifyChange comf MIOS_PARAMETER2, F ; inverse incrementer ... Best Regards, Thorsten.
TK. Posted September 9, 2011 Posted September 9, 2011 Which encoders should be reversed exactly? Best Regards, Thorsten.
yodabe Posted September 9, 2011 Author Posted September 9, 2011 Which encoders should be reversed exactly? Best Regards, Thorsten. Osc delay/transpose/assign sr 3 pin 0 Filter CutOff sr 3 pin 2 Filter Resonance sr 4 pin 0 Env depth/assign sr 4 pin 2 Env sustain/assign sr 5 pin 0 Env release/assign sr 5 pin 2 Osc attack/finetune/assign sr 2 pin 0 Osc decay/portamento/assign sr 2 pin 2 thx best regards
sidmonster Posted September 10, 2011 Posted September 10, 2011 Yes, this is possible by inversing the incrementer in main.inc: ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when an encoder has been moved ;; Input: ;; o Encoder number in WREG and MIOS_PARAMETER1 ;; o signed incrementer value in MIOS_PARAMETER2: ;; - is positive when encoder has been turned clockwise ;; - is negative when encoder has been turned counter clockwise ;; -------------------------------------------------------------------------- USER_ENC_NotifyChange comf MIOS_PARAMETER2, F ; inverse incrementer ... Best Regards, Thorsten. I am trying to do the same thing, I've added the line so that it looks like this: USER_ENC_NotifyChange comf MIOS_PARAMETER2, F ; inverse incrementer movf SID_MIDI_DEVICE, W ; exit if device ID != 0x00 skpz return and the encoders work in the opposite direction, but now I have to turn past several detents to increase by one increment. My encoders in general behave erratically when this line is added. Can you spot my mistake? I added it by copy/past in a text editor the main.inc file. Thanks for your help, looking forward to learning more about this since it's the first time I've done anything other than change din and dout assignments.
TK. Posted September 11, 2011 Posted September 11, 2011 Osc delay/transpose/assign sr 3 pin 0 Filter CutOff sr 3 pin 2 Filter Resonance sr 4 pin 0 Env depth/assign sr 4 pin 2 Env sustain/assign sr 5 pin 0 Env release/assign sr 5 pin 2 Osc attack/finetune/assign sr 2 pin 0 Osc decay/portamento/assign sr 2 pin 2 So, these are encoder number #1, 2, 3, 8, 9, 10, 11, 12 in the MIOS_ENC_PIN_TABLE (-> setup_* file) Workaround (simplified form, there are also ways to optimize this check but it would lead to more complicated code): ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when an encoder has been moved ;; Input: ;; o Encoder number in WREG and MIOS_PARAMETER1 ;; o signed incrementer value in MIOS_PARAMETER2: ;; - is positive when encoder has been turned clockwise ;; - is negative when encoder has been turned counter clockwise ;; -------------------------------------------------------------------------- USER_ENC_NotifyChange movf MIOS_PARAMETER1, W xorlw 1 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 2 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 3 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 8 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 9 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 10 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 11 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 12 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer ... [/code] Best Regards, Thorsten.
TK. Posted September 11, 2011 Posted September 11, 2011 and the encoders work in the opposite direction, but now I have to turn past several detents to increase by one increment. My encoders in general behave erratically when this line is added. Can you spot my mistake? In this case there is no software solution, you have to fix the encoder connections hardware-wise! (this shouldn't be so difficult, even if a PCB is used) Best Regards, Thorsten.
sidmonster Posted September 11, 2011 Posted September 11, 2011 In this case there is no software solution, you have to fix the encoder connections hardware-wise! (this shouldn't be so difficult, even if a PCB is used) Best Regards, Thorsten. Yes, they work fine when this line is not added, one detent per increment, and performance is good, and they work properly when I modify the hardware, so I thought that I made an error in the conkinde that was causing poor performance. It is no big deal to correct the hardware. I will just do that. Thanks~
yodabe Posted September 11, 2011 Author Posted September 11, 2011 (edited) So, these are encoder number #1, 2, 3, 8, 9, 10, 11, 12 in the MIOS_ENC_PIN_TABLE (-> setup_* file) Workaround (simplified form, there are also ways to optimize this check but it would lead to more complicated code): ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when an encoder has been moved ;; Input: ;; o Encoder number in WREG and MIOS_PARAMETER1 ;; o signed incrementer value in MIOS_PARAMETER2: ;; - is positive when encoder has been turned clockwise ;; - is negative when encoder has been turned counter clockwise ;; -------------------------------------------------------------------------- USER_ENC_NotifyChange movf MIOS_PARAMETER1, W xorlw 1 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 2 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 3 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 8 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 9 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 10 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 11 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer movf MIOS_PARAMETER1, W xorlw 12 skpnz comf MIOS_PARAMETER2, F ; inverse incrementer ... Best Regards, . thx Thorsten thats work but wiht this code the increment not work on osc env section (for a d s r) he work fine on sub menu (fin por phs pw k#2 k#3 k#5 k#5) and i have the same bug like sidmonster if turn the encoder slowly it not increment or decrement if turn normally or quickly thats work fine best regards my code : ;; -------------------------------------------------------------------------- ;; This function is called by MIOS when an encoder has been moved ;; Input: ;; o Encoder number in WREG and MIOS_PARAMETER1 ;; o signed incrementer value in MIOS_PARAMETER2: ;; - is positive when encoder has been turned clockwise ;; - is negative when encoder has been turned counter clockwise ;; -------------------------------------------------------------------------- USER_ENC_NotifyChange movf MIOS_PARAMETER1, W xorlw 2 skpnz comf MIOS_PARAMETER2, F ; inverse incre movf MIOS_PARAMETER1, W xorlw 3 skpnz comf MIOS_PARAMETER2, F ; inverse incre movf MIOS_PARAMETER1, W xorlw 13 skpnz comf MIOS_PARAMETER2, F ; inverse incre movf MIOS_PARAMETER1, W xorlw 14 skpnz comf MIOS_PARAMETER2, F ; inverse incre movf MIOS_PARAMETER1, W xorlw 8 skpnz comf MIOS_PARAMETER2, F ; inverse incre movf MIOS_PARAMETER1, W xorlw 9 skpnz comf MIOS_PARAMETER2, F ; inverse incre movf MIOS_PARAMETER1, W xorlw 10 skpnz comf MIOS_PARAMETER2, F ; inverse incre movf MIOS_PARAMETER1, W xorlw 1 skpnz comf MIOS_PARAMETER2, F ; inverse incre movf SID_MIDI_DEVICE, W ; exit if device ID != 0x00 skpz return ;; store encoder number in CS_MENU_USED_ENCODER - will be used by CS_MENU_ENC_CSInc later to set a new speed! movff MIOS_PARAMETER1, CS_MENU_USED_ENCODER ; comf MIOS_PARAMETER2, F ; inverse incrementer #if CS_MENU_USE_INCDEC_BUTTONS == 0 ;; if encoder #0 has been moved, jump to Control Surface Menu Encoder Handler movlw 0x00 ; encoder #0 cpfseq MIOS_PARAMETER1, ACCESS rgoto USER_ENC_Handler_NoMenu ;; get incrementer and jump to control surface menu encoder handler movf MIOS_PARAMETER2, W goto CS_MENU_ENC_Handler USER_ENC_Handler_NoMenu decf MIOS_PARAMETER1, F; decrement encoder number (the CS encoders begin at 0) #endif ;; jump to CS handler goto CS_MENU_ENC_CS_Handler Edited September 11, 2011 by yodabe
TK. Posted September 11, 2011 Posted September 11, 2011 and i have the same bug like sidmonster if turn the encoder slowly it not increment or decrement if turn normally or quickly thats work fine This is not a bug, but just an indication that this issue can't be solved via software. Please remove the changes and fix your hardware as well - it's simple! Best Regards, Thorsten.
yodabe Posted September 12, 2011 Author Posted September 12, 2011 Please remove the changes and fix your hardware as well - it's simple! Best Regards, Thorsten. yep i processing a new pcb board thx for your help Tk best regards
