m00dawg Posted September 22, 2011 Posted September 22, 2011 (edited) I opted to move away from the MB6582 button-matrix design and, instead, use standard shift-registers mounted on my control surface boards. Less modules, less wires to connect between boards, etc. This is primarily because I am limited in Eagle Standard and can't create a single control surface board (where a button-matrix would certainly make more sense). Thing is, I'm so used to using diodes for buttons but with just using shift-registers, I assume that they are no longer required (but probably don't hurt anything either)? I know the pull-up resistors are required to prevent phantom button presses and things but I assume the diodes are optional? Also, when does an isolation plane make sense? How about a power plane? The bottom plane is for ground but most of the top wires are for power, so I was curious if I should use an isolation plane, or if a power plan would even make sense. I hate wasting copper :) For the curious, I've included the first board I switched over to using on-board SRs. There's quite a few SMD parts on it but I figured that would make the layout easier, which seems to be the case (though I have more vias than I'd like). EDIT: For to ask about grounding unused pins for the input SRs? Yes? Edited September 22, 2011 by m00dawg
julienvoirin Posted September 22, 2011 Posted September 22, 2011 using signal diodes (1n4148) permits use of a matrix, i.e 64 buttons with only 8 outputs (1x74HC595) and 8 inputs (1x74HC165) some complexe example here http://midibox.org/forums/forum/43-midibox-blm/ more simple http://www.midibox.org/forum/index.php/topic,10476.msg79411.html the idea is the following : A column is ON, the others 7 are OFF. then we scan what Row is ON, corresponding to a button press. the do it again with next Column, etc...
m00dawg Posted September 22, 2011 Author Posted September 22, 2011 Though so, thanks for clarifying! This means, in my case, I won't need diodes since I won't be using a button matrix.
