I am 90% sure I burned the PIC18F452 correctly
I used the current 1.2b bootloader .hex using a jdm
I verified it and installed it on two different chips
The core module I used is from smashtv and am confident in the soldering work I've done
I've tried this with both chips in the core with the same results
I run MIOS Studio and after hitting Query I get
Operating System: MIOS8
Boar: MBHP_Core or similar
Core Family: PIC18F
Bootloader is up & running!
That's why I'm 90% sure about burning the PIC right
then in MIOS Studio I browse for mios_v1_9g_pic18f452.hex,
hit the start button, and after ten minutes of so it's done
after the loading I am not getting the reboot w/ copyright and ready msg described
I have an LCD connected and it only displays a single line of black squares
I know the pinout of the lcd and I've made 2 different cables for it
I have adjusted both the contrast and brightness with success
it is a Sharp lc95706 lm20x212
which is a 20 character 2 line lcd
it's possible I got a bad LCD since I don't know it's origin
Can I identify whether or not my core is working using MIOS Terminal?
I have a DIN and DOUT module if that will help me do some diagnostics.
Thank you in advance
I love the project
Posted (edited)
Hello dnhstv!
Ten minutes - I think the period is too long...
Edited by lemonhorse
The core module is definitely at least partially working. A ten minute upload really does seem very long. What MIDI interface are you using? (ie is it either on the white- or black-list on the wiki)
If your MIOS upload failed, you still only have the bootloader on the pic and you'll still only get a line of black bars, since the display isn't initialized.
My money is on a corrupted upload.
Yes, seems to be an upload problem, check the messages in the upload window, probably you are getting checksum errors or no response (timeout?)
The most simple way to check the DIN/DOUTs is via the MIDIO128 application as described here: http://www.midibox.org/dokuwiki/doku.php?id=home:mbhp:module:din
But first you need to upload MIOS8 successfully before MIDIO128 can be uploaded.
MIDI troubleshooting guide: http://www.ucapps.de/howto_debug_midi.html
First I'd like to apologize for missing the guide you linked me to TK
I felt horrible when I saw,"Please don't ask for help in the forum
before you haven't worked through this guide." in the first paragraph.
this morning I went through the midi interface troubleshooting guide
midi interface loopback worked
midi interface loopback with TX and RX pins on socket bridged worked
all midi input tests in the guide passed
LED flickers when attached to midi out
resistors double checked... diode double checked
optocoupler checked and replaced (I have many)
midi plug polarity is correct (surface mount jacks)
I performed all the core tests and get consistent results
4.9V at all points it's supposed to be at
Now I'm 98% sure it's not the PIC, Optocoupler, Diodes, Resistors, or Jacks
I have more than 5 of each and have tried them in different combinations
I have a core assembled on a board as well as a core on a breadboard giving me the same results
More detailed info on the MIOS upload attempts:
After selecting the mios_v1_9g_pic18f452.hex from the midi folder and clicking Start
Each Midi Out message repeats 16 times then progresses to the next message
This process takes about 14 minutes at which point I see
'Upload of 13312 bytes completed after 832.74s (0.02 kb/s)'
So for some reason MIOS studio seems to think it completed the upload
Even though this transfer rate indicates something is wrong
TK suggested
"check the messages in the upload window, probably you are getting checksum errors or no response (timeout?)"
I am not sure which window is the upload window
but I see no errors anywhere
other than the out messages being repeated exactly 16 times each
is this normal or a sign of timeouts?
At this point I think we must blame the midi interface
It is a Tascam Fireone which is a crap interface at best
I am on OSX, but will probably attempt this on Windows 7 later today just in case.
I know for a fact that the drivers are significantly different between windows and osx.
I guess in the meantime I'll start shopping for a good dedicated MIDI interface.
Thanks for your help guys
You can close this thread.
I installed XP SP3 and the upload worked in 11.75s (1.11 kb/s)
So I guess this is for your white/black list
Tascam FIREONE - OSX Lion - FAIL
Tascam FIREONE - Windows XP SP3 - SUCCESS
The FIREONE drivers are final and abandoned so this won't change.
Of course it could also be a difference between
MIOS Studio XP and OSX versions also...
So it finally reads...
"Application is up & running!"
Now it's time to have fun...
