WidgetOz Posted March 11, 2012 Posted March 11, 2012 I bought the Base Parts Kit from SmashTV and have been building the unit today. base board is complete and then I notice that the rear panel for the MB-6582 has 4 holes for `feedback' pots and a hole for a D Connector. it has taken hours of scrolling through the forums to find out that the pots are, apparently, 500K dual-gang, but i can't find any information of the D-connector and how it is terminated to the base board. Is there a proper list of parts specific to a full build of the MB-6582? Lists appear for the base board and for the control surface but other bits are not listed. Similarly build instructions miss this out as well. maybe I am tired after 4 hours building and fruitless hours scrolling the internet - HELP
Hawkeye Posted March 11, 2012 Posted March 11, 2012 Maybe the frontpanel photo tutorial will help you - it has a complete list of used components: The rest comes in Tims/SmashTVs mighty fine Baseboard Parts package. Greets, Peter
technobreath Posted March 11, 2012 Posted March 11, 2012 The d connector is usually used for custom breakout stuff for example aout stuff - control voltage, and is not something u need to have if u just want the synth as is, and is not gonna control external stuff from it. Feedback pots are not either necessary, but it takes the audio output, and route it into the sid again. This is a mod and is not used either in the original mbsid design, but makes up for some nice variation of the original sound. Phat. The purpose of those now that u know it, might provide a alight hint on how to wire them too... Much info is gathered in the wiki also.
WidgetOz Posted March 16, 2012 Author Posted March 16, 2012 The d connector is usually used for custom breakout stuff for example aout stuff - control voltage, and is not something u need to have if u just want the synth as is, and is not gonna control external stuff from it. Feedback pots are not either necessary, but it takes the audio output, and route it into the sid again. This is a mod and is not used either in the original mbsid design, but makes up for some nice variation of the original sound. Phat. The purpose of those now that u know it, might provide a alight hint on how to wire them too... Much info is gathered in the wiki also. Hi and thanks, The photo tutorial covered the points needed (value of pots and the D connector). After all my browsing I never came across that page at all..... I can understand that the pots and D connector may not be part of the main build and are optional and for future expansion but it seems odd to have pointed everyone one to a panel design that has 5 holes in it and no mention anywhere (except the aforementioned tutorial) as to why they are there or that you can just plug them.... Anyway, that seems all resolved now. if I may ask just one further question, is there any schematics relating to the power supply section and its options? It would be really useful to actually see what the board has in that area and for those that can read them, make the selection easier. I want to run from a single AC supply with 8580 chips so I am guessing option C but some technical details in that area would not go amiss.
Gilesjuk Posted March 16, 2012 Posted March 16, 2012 Feedback pots won't work for SwinSID users, so it would be a bit of a waste to include them.
WidgetOz Posted March 16, 2012 Author Posted March 16, 2012 Feedback pots won't work for SwinSID users, so it would be a bit of a waste to include them. Hi, I wasn't suggesting that they be included in any kit but that the build documentation should at least have a paragraph saying something like " there are 5 extra holes on the back panel that are usually used for x, y and z. For standard builds these holes can be simply blocked off using any spare components. Refer to a.b.c for applications that utilise these holes" That would have saved hours of frustrating searching with absolutely no conclusive results until this thread pointed to the photo tutorial, after which at least the first half had been answered......
Gilesjuk Posted March 16, 2012 Posted March 16, 2012 Maybe, but then this is a project which isn't for beginners. It's not a product, it's a project. There is mention of the pots in the Wiki and you can see them in the photos. Having holes in the case won't kill anyone :) The expansion port is also optional and there's no standard to how to wire it, it is up to the builder.
