Hi All
After reading reading reading I've started a new midiBox project.
I already own a midiBox128 and a midiBox64 project for controlling lighting software.
But now I've started a LPC17 project to replace the old 1 with 8+ LCD's.
Everything is running, code for Din & Dout is ready.
For now I'm testing with 1 LCD but the plan is to have 8 or more LCD running under Mios32.
I can't find where i can modify the lcd_device_set code
I would like to have it like this:
LCD_1 E-pin ---> I take from J15A
LCD_2 E-pin ---> I take from J15B
LCD_3 E-pin ---> I would like to have on J10.D0
LCD_4 E-pin ---> I would like to have on J10.D1
and so on....
Where do i modify this? I should think in Mios32_Board? But I can't find it.
Can someone point me in de right direction?
Ps Big thx again to TK and his team for this wonderful new project.
Greetings
Gert
Hi Gert,
I will update the "universal" lcd driver under modules/app_lcd/universal soon to simplify such changes, currently they are not obvious (basically you would have to change each line where MIOS32_BOARD_J15_E_Set() is called, it makes sense to add an additional SW layer to overwrite the default function)
Ah,
Okeey TK, for now i wil just put all J10 outputs in open drain mode, and use external pull-up to 5v.
I think all E lines are anabled at start up, so all displays wil get the same correct initialisation. Correct?
and after init, i just set/reset the correct J10 pin before any Lcd_print command
I'm still a bit confused with the following tutorial:
u8 pin = (midi_package.note - MIDI_STARTNOTE)
& 0x7f
// turn on LED
MIOS32_DOUT_PinSet(pin, 1);
What does the "& 0x7f" ???
Maybe silly question...
But Isn't it, if I set: MIOS32_DOUT_PinSet( 0 , 1 );
Thad the first LED will light up?
Greetings
Gert
ps: TK do you mind giving me access to the programmer lounge. maybe i can do there some good idea's.
access granted.
Still got a problem,
The first LCD works perfect, but whene i connect the Enable line to 1 of the J10 pins. the LCD does nothing...
Does not init at startup.
At initialisation off te application, I set all J10 pint as output open drain.
Even whene i don't connect the E line to annything (pull up connected) the LCD won't init at start up. (E line should be high)
Am I missing something?
At de datasheet for the LCD, the E line is a puls train. Right now i dano't have a scope with me to check what the E line off J15A/J15B does.
But i thought, whenever you wonna write to a LCD, the E pin off thad LCD was just high(+5V) the entire time.
Can someone point me in the right direction?
Greetings
Gert
Found my point to the right direction....
Enable line is a select line and a kind of a clock line.
So, clamping it to ground or vss wouldn't do the trick.
A multiplexer is answer to my question i guess.
To-morrow i will test it with a 1 to 8 multiplexer.
Greetings
Gert
