Zossen Posted May 7, 2012 Report Posted May 7, 2012 Hi can i use this with normal MIDI-cable or only with the screw-able connector for this Port??? http://www.reichelt.de/Diodeneinbaubuchsen/DIO-50S-EMS/index.html?;ACTION=3;LA=5;ARTICLE=46277;GROUPID=5182;artnr=DIO-50S+EMS;SID=11T2LOxn8AAAIAAG1cmio5d3955e94627696a3d2276bb8d926c6a best regards Zossen
Imp Posted May 7, 2012 Report Posted May 7, 2012 There is no special plug for this, it's meant to be used with DIN plugs. So, yes, normal MIDI cable will work.
Zossen Posted May 7, 2012 Author Report Posted May 7, 2012 THX so i can use all standart cable and not only this part http://www.reichelt.de/Diodenstecker/DIO-50S-SMS/index.html?;ACTION=3;LA=5;ARTICLE=46262;GROUPID=5180;artnr=DIO-50S+SMS;SID=11T2LOxn8AAAIAAG1cmio5d3955e94627696a3d2276bb8d926c6a so its a good alternative
nILS Posted May 7, 2012 Report Posted May 7, 2012 It does work with regular DIN connectors. There is no special plug for this, it's meant to be used with DIN plugs. No. There is a special plug for this. It has a little ring on it that lets you screw it to the socket tightly. Absolutely awesome for stuff that stays plugged in for a while. :hyper: http://www.reichelt.de/?ARTICLE=46262 (as seen above)
Jeff009 Posted October 17, 2012 Report Posted October 17, 2012 Hi can i use this with normal MIDI-cable or only with the screw-able connector for this Port??? http://www.reichelt.de/Diodeneinbaubuchsen/DIO-50S-EMS/index.html?;ACTION=3;LA=5;ARTICLE=46277;GROUPID=5182;artnr=DIO-50S+EMS;SID=11T2LOxn8AAAIAAG1cmio5d3955e94627696a3d2276bb8d926c6a best regards Zossen I bought one of these from DigiKey and they work great.
