Spirit Posted September 24, 2012 Report Share Posted September 24, 2012 Hi everyone. I'm trying to find all the Parts on "Farnell" But i have some issue's finding the Correct Rectifier B40C800 Is it realy nessecary i need the B40C800 or can i also use one with Higher Value's. ( On the Ucapps page i see on the PDF and images there is used a B80C1500 and on the partlist and Explanation the B40C800 should be used..) So can someone clear this Up for me as i'm sort a beginnen with Small Elctronic parts.... Thanks in advanced.. /Spirit Quote Link to comment Share on other sites More sharing options...
rosch Posted September 24, 2012 Report Share Posted September 24, 2012 the first 2 digits are the maximal allowed incoming VAC, the second number is the maximum of mA, so a B80C1500 means bridge rectifier for max 80V alternating current and a max of 1.5A. if they have a matching pinout to the one recommended you can use higher values. Quote Link to comment Share on other sites More sharing options...
Spirit Posted September 24, 2012 Author Report Share Posted September 24, 2012 oke thanks and just to be sure. I see a other one the AM150 :smile: 50V and 1.5A this one should also work as im useing a Powersupply of 12V 600mA? http://nl.farnell.com/multicomp/am150/bridge-rectifier-1-5a-50v/dp/9381422 And the pinlayout dont matter as i'm planning to Create my own PCB.. /spirit Quote Link to comment Share on other sites More sharing options...
NorthernLightX Posted September 24, 2012 Report Share Posted September 24, 2012 You're able to create your own PCB but not able to read a bridge rectifier rating even after it is explained by another forum member? That's perculiar imho. Anyway, yes, a recifier rated for 50V(ac) and 1,5A (1500mA) is sufficiently rated to put behind a PSU that supplies 12V(ac) at 600mA. Rule of thumb is that you multiply the Vac rating by 1,4 to (roughly) know the Vdc rating, and 12 x 1,4 is 16,8 which is still way below 50. Good luck! Quote Link to comment Share on other sites More sharing options...
