Spirit Posted September 24, 2012 Posted September 24, 2012 Hi everyone. I'm trying to find all the Parts on "Farnell" But i have some issue's finding the Correct Rectifier B40C800 Is it realy nessecary i need the B40C800 or can i also use one with Higher Value's. ( On the Ucapps page i see on the PDF and images there is used a B80C1500 and on the partlist and Explanation the B40C800 should be used..) So can someone clear this Up for me as i'm sort a beginnen with Small Elctronic parts.... Thanks in advanced.. /Spirit
rosch Posted September 24, 2012 Posted September 24, 2012 the first 2 digits are the maximal allowed incoming VAC, the second number is the maximum of mA, so a B80C1500 means bridge rectifier for max 80V alternating current and a max of 1.5A. if they have a matching pinout to the one recommended you can use higher values.
Spirit Posted September 24, 2012 Author Posted September 24, 2012 oke thanks and just to be sure. I see a other one the AM150 :smile: 50V and 1.5A this one should also work as im useing a Powersupply of 12V 600mA? http://nl.farnell.com/multicomp/am150/bridge-rectifier-1-5a-50v/dp/9381422 And the pinlayout dont matter as i'm planning to Create my own PCB.. /spirit
NorthernLightX Posted September 24, 2012 Posted September 24, 2012 You're able to create your own PCB but not able to read a bridge rectifier rating even after it is explained by another forum member? That's perculiar imho. Anyway, yes, a recifier rated for 50V(ac) and 1,5A (1500mA) is sufficiently rated to put behind a PSU that supplies 12V(ac) at 600mA. Rule of thumb is that you multiply the Vac rating by 1,4 to (roughly) know the Vdc rating, and 12 x 1,4 is 16,8 which is still way below 50. Good luck!
