NorthernLightX Posted October 13, 2012 Posted October 13, 2012 If anyone has an (unfinished is fine) IIC module in decent shape (no burned components or lifted tracks please :)) that they want to get rid of; I'm looking for one to add a Midi-in port to my MB6582 for the internal keyboard. If nothing turns up I'll just order a PCB and PIC at Smash.
Shuriken Posted October 13, 2012 Posted October 13, 2012 (edited) I should be able to flash a pic for you. I'll have to check tomorrow (i burned a PIC18F4685) to see if it is working. That way you should be able to do a low value order at smash. Edited October 13, 2012 by Shuriken
NorthernLightX Posted October 13, 2012 Author Posted October 13, 2012 (edited) I also got a PM from Rosch that he maybe has a spare PIC16F88 which should already have the correct firmware. I like cleaning out leftovers, and another look at the schematic revealed it's so simple I'll probably just build it on veroboard. I'll keep in mind that you have a burner though. Always handy :) P.S. I have a 40 pin ZIF socket, real nice piece, bought it years ago when I still had plans to build a PIC programmer. Maybe you can use it on your programmer? Edited October 13, 2012 by NorthernLightX
Shuriken Posted October 13, 2012 Posted October 13, 2012 I bought this a couple of months ago. Goes nice with the Pickit i have. Thanks for the offer though.
rosch Posted October 13, 2012 Posted October 13, 2012 oh i could use a ZIF socket! funny backlog traders, aren't we?
NorthernLightX Posted October 13, 2012 Author Posted October 13, 2012 That is exactly the same ZIF socket as I have, only mine is blue (which is much better for the bits ofcourse, everyone knows that :tongue: ) and not attached to a PCB yet. @ Rosch: shall I put it in the box together with your PSU? Did you manage to test the 16F88 PICs you have left over? Cheers, Alex.
Lamouette Posted October 15, 2012 Posted October 15, 2012 I have PCB without any components on it (like new, i can give you one, if you want ! :flowers:
NorthernLightX Posted October 15, 2012 Author Posted October 15, 2012 Hi Lamouette, is it a single IIC board or the quad version? Since I only need one extra MIDI in port a quad IIC board would be largely wasted.
Lamouette Posted October 16, 2012 Posted October 16, 2012 i bought 4 IIC board before the Quad IIC was available, and i didn't use them, so i can post one for you ! Just give me your adress ! Bye
rosch Posted October 16, 2012 Posted October 16, 2012 cool! seems you got it solved? if not, i'd send you the ones i have and you can check which are already flashed.
NorthernLightX Posted October 16, 2012 Author Posted October 16, 2012 Hi Rosch, Lamouette was kind enough to send me a PCB, but afaik it is unsoldered, so I could still use a (flashed) 16F88 PIC :whistle: (I'll send you the ZIF socket anyway :flowers: )
