tomtiki Posted December 10, 2012 Posted December 10, 2012 Is there a way to send patch changes to a headless (no control surface) Midibox SID? I'm thinking of a performance situation where patches could be loaded in advance and I would just select them from my control keyboard. I suppose it would be the same situation with a rackmount Midibox SID. Sorry if this is an obvious question. I did not see this information in the docs. Thanks, Tom
Labelwhore Posted December 10, 2012 Posted December 10, 2012 CC #0 is to select the bank, and CC #32 is to select the patch. (btw these are standard CC values for bank/patch changes)
tomtiki Posted December 11, 2012 Author Posted December 11, 2012 According to the midibox sid CC implementation chart : http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fdoc%2Fmbsidv2_cc_chart.txt CC0 is bank change and CC32 is "Voice 123 Portamento rate" I obviously have something confused. If someone could point me at information on how to do patch and bank changes from a practical sense (on an actual MIDI controller keyboard), then I will go read that before asking any more dumb questions. Has anyone ever wired a numeric keypad directly into the Midibox SID so that patch and bank could be typed in directly? I have a Yamaha MU5 Tone module with a built in keyboard and display that does this. Here is a commercial product that sends patch change commands : http://www.musictechnologiesgroup.com/midipatch.htm If this functionality (bank/patch change via keypad) could be added to the Midibox SID, it would be pretty much what I am looking for. Thanks, Tom CC #0 is to select the bank, and CC #32 is to select the patch. (btw these are standard CC values for bank/patch changes)
tomtiki Posted December 11, 2012 Author Posted December 11, 2012 A simple description of what I am looking for is a Midibox SID version of a Yamaha MU5 : http://usa.yamaha.com/products/music-production/tone-generators/mu5/?mode=model The built in music keyboard is not necessary, but would be nice. Patches can be changed from the built in keys. I would like to be able to type in a patch number directly rather than using a rotary encoder. I'm thinking a 4x4 matrix keyboard. My end use of this would be for my son's marching band to be able to integrate SID/chiptune type sounds into their performance. I realize that i could build a separate box that would send these bank/patch changes, but that would use the MIDI IN port...then I would need a merger. If this was doable through the CORE without going through MIDI, it would be much simpler. I found the project that allows a C64 keyboard into a Midibox project, but that would make the system too large and contain many unnecessary keys. Thoughts? Sorry if I am missing something obvious. --tom
Labelwhore Posted December 11, 2012 Posted December 11, 2012 (edited) hmmm... I'm not sure where I got CC# 32 from. Regardless, CC# 0 is bank select, then use a standard program change message to select the patch. In essence, any device that can send patch change messages will work, be it hardware, or software. Of course the other option is to add a minimal control surface because the default function of the menu knob is to change patches. Edited December 11, 2012 by Labelwhore
tomtiki Posted December 12, 2012 Author Posted December 12, 2012 (edited) I have a Midibox SID with a basic control surface. Using the knob to select random patches is not the best when you are trying to pick a specific patch, or a higher numbered patch. In performance, there are generally lighting problems and these displays can be hard to read. Being able to enter a patch number via a keypad would be more efficient. A display would be nice, but not necessary. I may look at the C64 8x8 keyboard encoder to see if I can make that work. The software would then have to be changed to accept input from the keypad. There should be a way to do this as a Midibox module which could plug into the DIN/DOUT bus rather than MIDI. That would avoid the requirement for a MIDI merger. Update : Just found some 16 button keypads in my parts box. They are wired as individual switches with a common ground. Keys are 0-9, A, B, C, D, # and *. I could just connect this keypad to a DIN module, then I would just need software to make it work. Pointers on how to do this would be appreciated. --tom hmmm... I'm not sure where I got CC# 32 from. Regardless, CC# 0 is bank select, then use a standard program change message to select the patch. In essence, any device that can send patch change messages will work, be it hardware, or software. Of course the other option is to add a minimal control surface because the default function of the menu knob is to change patches. Edited December 12, 2012 by tomtiki
tomtiki Posted December 12, 2012 Author Posted December 12, 2012 So, perhaps I should be asking : - Will this even work? (adding a keypad via a DIN module) - If it will work, would it be difficult for Midibox SID software to process patch/bank changes entered on the keypad? --tom
Hawkeye Posted December 12, 2012 Posted December 12, 2012 (edited) Hi, while it may probably be coded into the MIDIbox SID program, it will require a custom pic assembly job for your needs - would probably be easier (but more expensive) to invest in a midi merger and a lpc17 core, for which numeric keypad input coding and then sending the cc would be much easier. You might even be lucky to request that feature from TK. to put it into the MIDIbox NG, he is currently working on ;-). If you can live with a set of say ten preprogrammed patches for a live set, it would work even without modifying any code in the MIDIbox NG, just program the patch changes to be emitted, when pushing a button. I think, this may be even better in a live environment. Have a LED indicate the "song" you are currently playing on, press the next button to load the next patch. And it could send to multiple synths, to program them all... This can already be done with the MIDIbox SEQ V4 Mixer by the way... so if you drive your MBSID via MBSEQ anyways, you would not need a merger... Many greets, Peter Edited December 12, 2012 by Hawkeye
tomtiki Posted December 14, 2012 Author Posted December 14, 2012 Peter, I appreciate the answer. I'm going to investigate some different options. Of course, I have plenty of other projects to do. Thanks, Tom [
