TK. Posted March 28, 2013 Posted March 28, 2013 I migrated MIOS Studio to the most recent Juce 2.0.38 version in the hope that this could solve the MIDI communication issues which have been noticed by some Windows users when they are trying to access files from SD Card with the MIOS Filebrowser. Since I'm not able to reproduce these issues on a "modern Win7" and on an "antique WinXP" notebook, I rely on your feedback! Please try out this version and inform me, if they are working at your side (of course, also positive replies are very welcomed): Windows: /edit: obsolete - please download the latest version under http://www.ucapps.de/mios_studio.html MacOS: /edit: obsolete - please download the latest version under http://www.ucapps.de/mios_studio.html Linux: /edit: obsolete - please download the latest version under http://www.ucapps.de/mios_studio.html IMPORTANT: the new Juce version doesn't solve the USB MIDI driver issues under Windows. If even a "query" is failing, you either have to install the GM5 driver, or for the case that this driver also doesn't work, you've to use the "single_usb" option as explained here: http://www.ucapps.de/mios32_bootstrap_newbies.html Best Regards, Thorsten.
Arkay Posted March 29, 2013 Posted March 29, 2013 TK, Works perfectly for me under Arch Linux. Not what you need to know with regard to Windows but feedback none the less :smile: Cheers, Arkay.
TK. Posted March 30, 2013 Author Posted March 30, 2013 Thanks for testing! :) Any input from Windows and MacOS users? Before an official release I would like to ensure, that the new Juce version hasn't corrupted anything. Best Regards, Thorsten.
kpete Posted March 30, 2013 Posted March 30, 2013 (edited) Hi TK, I went ahead and did some testing. I have an HP Pavilian running Windows 7 - 64 bit. I thought that the best test would be to copy the MIOS Studio executable code to my LPC SD card and back again using the browser in MIOS Studio. So I uploaded and then down loaded the same .exe file. This worked fine even with the file size of 2.9meg. I then ran the copied exe and it performed as expected so I would say it's a go. I did see something that was confusing and it had to do with deleting files on the SD card using the MSD mode and doing the upload/download functions with MIOS Studio. During this testing I had deleted a file on the SD card called MIOS_Studio.exe using the MSD file function. I then tried to copy this same file name from the PC to the SD card using the file browser. Problem was that it didn't let me do it. I suspect that the MidiBox software thought the file was there even though it wasn't displayed on the browser window. After I changed the target file name to MIOS_1.exe, this file copied fine. Maybe I shouldn't even talked about this little issue :sad: Pete PS-And I used the "Rescan MIDI Devices" a lot to get the ports working again after going into MSD mode and having to remove the USB cable get out of MSD mode without restarting the MIOS Studio application. Please don't remove this. Edited March 30, 2013 by kpete
TK. Posted March 31, 2013 Author Posted March 31, 2013 Thank you very much! :) I will test the filename issue soon - it could be, that the delete command doesn't check the attributes of a directory entry. Best Regards, Thorsten.
TK. Posted April 5, 2013 Author Posted April 5, 2013 Topic closed - MIOS Studio 2.4.4 has been released.
