Spirit Posted June 26, 2013 Report Posted June 26, 2013 hi everyone. i have the issue if i connect my LPC with usb to the pc and startup Mios studio. it says "No response From mios8 or mios32 core!" if i press Quary i get the same message.. but if i press a button +-20 times with a CC assigned on it. i will get a Midi input. and if i then press Query then Mios studio sees the LPC.. and i can acces the SD card. i realy wonder is it something i done wrong or is it a known issue from the LPC.. kind regards, spirit
Duggle Posted June 27, 2013 Report Posted June 27, 2013 I get some similar issues, sometimes. I usually power cycle the core and restart MS when this happens.
John E. Finster Posted June 27, 2013 Report Posted June 27, 2013 Same here. Sometimes the core doesn´t seem to respond to MS no more for no apparent reason. Restarting the core and MS normally does the trick. You could connect the core via midi interface (if handy of course) and check if the core shows the same "symptoms". If so, there might be a problem with the core. If not it might be that your pc has problems with the gm5 midi driver that the Midibox uses (assuming you are using a windows based computer).
Spirit Posted June 28, 2013 Author Report Posted June 28, 2013 yes i run windows 7 i allways have this the first time i plug in the USB and startup MS. and if i press +- 20 times a button, it works oke.. but i will try to connect my BCF2000 with some Din5 cabels to the core and see if this makes any differnce as i also have been thinking that its a Problem from a Windows driver.. in the end its not realy a big issue. but i just wondered if other poeple has the same as i have... /spirit
kpete Posted June 29, 2013 Report Posted June 29, 2013 Yes, a lot of others have seen this problem with Windows OS. I am surprised that nobody provided information about the SINGLE USB PORT solution. With your last post indicating that you use Windows 7, this is defiantly the problem. All my problems went away when setting this option in the MIOS boot loader.
Duggle Posted June 30, 2013 Report Posted June 30, 2013 I'm well acquainted with the single USB port option. It can make a huge difference, but it does not entirely 100% fix the occasional failure to communicate.
kpete Posted June 30, 2013 Report Posted June 30, 2013 Spirit, If you haven't done this yet, you should set the "Single USB" option. It is described here. This option can only be set while running the Bootloader update code. Use Mios Studio and enter: set single_usb 1 store Hope this fixes your problem.
Spirit Posted July 1, 2013 Author Report Posted July 1, 2013 does this also mean i only get 1 usb port on Mios.. because i also have a MB_MF module and its on USB port 3. and the Mios8 core respont right away no issue with that one.. /spirit
TK. Posted July 1, 2013 Report Posted July 1, 2013 Unfortunately yes! This is a Windows limitation. If you've luck, multiple USB MIDI ports will work with the GM5 driver, or with the Korg driver. See also the bottom of this page: http://www.ucapps.de/mios_studio.html Best Regards, Thorsten.
Spirit Posted July 2, 2013 Author Report Posted July 2, 2013 Nice!!!! thanks the GM5 drivers does the trick :rofl: thanks everyone and offcourse TK for this wonderfull project.. /spirit
nihle Posted July 18, 2013 Report Posted July 18, 2013 (edited) hello, I am running into a similar problem. I have put bootloader on an STM32F4, the green led turns on as it should. I Start MIOS Studio and select the IN (1) and OUT (2) port of the MIDI interface. But i get a "No response From mios8 or mios32 core!" no matter how many times i press query. I have been stuck on this for 2 days now. One more and i wont have any hair to pull off my head :(. Edited July 18, 2013 by nihle
TK. Posted July 22, 2013 Report Posted July 22, 2013 This could be related to a different problem - I haven't tested the STM32F4 based bootloader on a Windows PC yet; only MacOS Best Regards, Thorsten.
