lukas412 Posted November 23, 2013 Report Posted November 23, 2013 So I am trying to connect my mbseq with lpc17 core to my network and I am having some issues. I get the following error in mios studio. The error continuously repeats. [9653.302] [EMAC_ReadPacket] ERROR during receive: [9653.302] [network_device_read] - Multicast Frame [9653.304] [network_device_read] - Broadcast Frame [9653.304] [network_device_read] - CRC Error in Frame [9653.304] [network_device_read] - Symbol Error from PHY [9653.306] [network_device_read] - Range error(exceeded max size) [9653.306] [network_device_read] - last Fragment in Frame Any ideas? Thanks, Luke
Tr1ptron1c Posted November 24, 2013 Report Posted November 24, 2013 Hi midiboxer's, i have the same problem on 2 lpcCores (mbseqv4l / midiboxNG). I tried several configurations when directly connected to a laptop or connected to a fritzbox router ( w/o DHCP or with static IP config ) thanks in advance Henrik
TK. Posted November 24, 2013 Report Posted November 24, 2013 This is strange! It seems that invalid frames are sent in the network. I hope that at least the actual OSC packets are sent/received correctly. Could you please try this version? (I disabled the error message): -> http://www.ucapps.de/mios32/midibox_seq_v4_079_pre5.zip Best Regards, Thorsten.
Tr1ptron1c Posted November 24, 2013 Report Posted November 24, 2013 Thanks a lot for your fast help: :smile: I will try it out tomorrow evening ^^ Have to sleep now :( gn8
TK. Posted November 25, 2013 Report Posted November 25, 2013 Ethernet PHY error messages are now disabled by default in the new releases V4.079 and V4L.079 Best Regards, Thorsten.
lukas412 Posted November 27, 2013 Author Report Posted November 27, 2013 Thanks TK this fixed my issue, seems to be connecting fine now!
