Marxon Posted January 29, 2014 Posted January 29, 2014 Hi, unfortunately i have some two problems with my new STM32F4 core module. I uploaded the actual bootloader 1.015 and Midibox NG 1.029 version. This ports are wired J16, J8/9, J19, J15A and J15_S. Problem 1: The event Event Pool Allocation is 24480 of 24576 bytes (99%) exactly like using the LPC1769 core. Shouldn't be there more bytes available :question: Problem 2: The LCD does not work (backlight and contrast are ok). It is a 2x16 HD44780 display. I have triple checked the wiring and soldering. TK, your help is needed :) Best regards Marxon
ilmenator Posted January 29, 2014 Posted January 29, 2014 (edited) Did you compile for the new target? Edit: ok, I just saw that you can now download a binary version for STM32F4, and you skip compiling yourself. So, you are using that one? Edited January 29, 2014 by ilmenator
Marxon Posted January 29, 2014 Author Posted January 29, 2014 (edited) Hi ilmenator! I have not compiled something. Just downloaded and uploaded to the core: http://ucapps.de/mios32/mios32_bootloader_v1_015.zip http://ucapps.de/mios32/midibox_ng_v1_029.zip EDIT: DIN, DOUTS and the SD card are working (if that matters). Edited January 29, 2014 by Marxon
sneakthief Posted January 29, 2014 Posted January 29, 2014 Sorry if this is obvious: is J15_S set for 5V?
Marxon Posted January 29, 2014 Author Posted January 29, 2014 Sorry if this is obvious: is J15_S set for 5V? Yeah, it does not hurt to ask ;) J15_S is set to 5V Best regards Marxon
sneakthief Posted January 29, 2014 Posted January 29, 2014 OK, open MIOS, clear your terminal screen and send load the Bootloader 1.015 hex file - not the MIDIbox NG application. -> What does the terminal say at the very top? For exmaple, my STM32F4 core isn't hooked to and LCD or anything else and it says: [386343.822] Initialize LCD #1 [386343.886] Failed - no response from LCD #1.1 [386343.886] Initialize LCD #2 [386343.950] Failed - no response from LCD #2.1
sneakthief Posted January 29, 2014 Posted January 29, 2014 (edited) Also, I just compiled the MIDIbox NG application for the STM32F4 on my pc using the latest SVN source. You can try it out: http://sneak-thief.com/MIDIboxNG/project.hex It loads fine and gives me the appropriate message for my setup: [387180.219] [MBNG_LCD] no response from CLCD #1.1 [387180.220] [MBNG_LCD] no response from CLCD #2.1 Edited January 29, 2014 by sneakthief
Marxon Posted January 29, 2014 Author Posted January 29, 2014 After uploading your .hex MIOS gives this output: [78833.839] Init DHCP [78834.846] SD Card connected: [78835.015] [MBNG_FILE_C:317] WARNING: no CC number expected for EVENT_ENC due to type: Disabled [78835.443] [MBNG_FILE_C] Event Pool Number of Items: 734 [78835.443] [MBNG_FILE_C] Event Pool Allocation: 24480 of 24576 bytes (99%) [78835.450] [MBNG_FILE_L] DEFAULT.NGL hasn't been changed; reading labels from existing DEFAULT.BIN file. [78835.451] [MBNG_FILE_L] 7 labels found in /DEFAULT.BIN file [78835.456] [MBNG_FILE_S] loading snapshot #13 from /DEFAULT.NGS
Marxon Posted January 29, 2014 Author Posted January 29, 2014 Entering "system" into the terminal gives this: [78917.869] Application: MIDIbox NG V1.029 [78917.870] MIDI Monitor: disabled [78917.870] MIDI Monitor Filters: enabled [78917.870] MIDI Monitor Tempo Display: disabled [78917.870] Print AOUT Config: TODO [78917.870] lcd_type: 0x00 - CLCD [78917.870] lcd_num_x: 1 [78917.870] lcd_num_y: 1 [78917.870] lcd_width: 16 [78917.870] lcd_height: 2 [78917.870] Event Pool Number of Items: 734 [78917.871] Event Pool Allocation: 24480 of 24576 bytes (99%)
sneakthief Posted January 29, 2014 Posted January 29, 2014 I see there's nothing about LCD's, like mine: [389191.893] [MBNG_LCD] no response from CLCD #1.1 [389191.894] [MBNG_LCD] no response from CLCD #2.1 [389191.894] Init DHCP [389196.915] SD Card not found
sneakthief Posted January 29, 2014 Posted January 29, 2014 (edited) But what does it say when you ONLY load the bootloader, like I asked above? Mine again: [389537.459] Initialize LCD #1 [389537.523] Failed - no response from LCD #1.1 [389537.524] Initialize LCD #2 [389537.587] Failed - no response from LCD #2.1 [389537.588] [389537.588] ==================== [389537.589] Bootloader 1.015 [389537.599] ==================== [389537.602] [389537.613] Checking Bootloader... [389537.633] No mismatches found. [389537.635] The bootloader is up-to-date! [389537.651] You can upload another application now! [389537.673] Or type 'help' in MIOS Terminal for additional options! Edited January 29, 2014 by sneakthief
Marxon Posted January 29, 2014 Author Posted January 29, 2014 [79878.592] Initialize LCD #1 [79878.649] [79878.649] ==================== [79878.649] Bootloader 1.015 [79878.660] ==================== [79878.662] [79878.674] Checking Bootloader... [79878.751] No mismatches found. [79878.754] The bootloader is up-to-date! [79878.769] You can upload another application now! [79878.791] Or type 'help' in MIOS Terminal for additional options!
sneakthief Posted January 29, 2014 Posted January 29, 2014 (edited) So, we can see that it's "initialized". I think this output below only shows the stored CLCD config and NOT the actual one because it says the same on mine when I type "system" in the MIDIbox NG application: [78917.870] lcd_type: 0x00 - CLCD [78917.870] lcd_num_x: 1 [78917.870] lcd_num_y: 1 [78917.870] lcd_width: 16 [78917.870] lcd_height: 2 Edited January 29, 2014 by sneakthief
sneakthief Posted January 29, 2014 Posted January 29, 2014 At this point, the only possibilities are: 1. Dead CLCD - time to test another CLCD? 2. Something weird with the software and/or configuration - das Heisst: keine Ahnung... TK! Wo bist du denn? :P 3. Bad wiring between the STM32F4, the 74HC595 and the CLCD. Did you try another 74HC595? - time to post a picture of your wiring (both sides, high-res please)
Marxon Posted January 29, 2014 Author Posted January 29, 2014 (edited) 1. LCD works with LPC core 2. Ehrlich TK, zu der Uhrzeit solltest du noch online sein ;) 3. Checked wiring 10 times. Also tried another 74hc595. Edited January 29, 2014 by Marxon
Marxon Posted January 29, 2014 Author Posted January 29, 2014 Damn! Kick me in my ass! I checked everything... Really everything? No, i left out the resistor array which turns out to be a 10k ohm array. :angry: :angry: :angry: This might be the problem! I am going to change it and post result in some minutes...
Marxon Posted January 30, 2014 Author Posted January 30, 2014 (edited) It works!!! :hyper: :hyper: :hyper: Edited January 30, 2014 by Marxon
TK. Posted February 1, 2014 Posted February 1, 2014 Nice that you find the error! :) Here a preliminary version which provides more event pool memory for the STM32F4: http://www.ucapps.de/mios32/midibox_ng_v1_030_pre1.zip Best Regards, Thorsten.
Marxon Posted February 2, 2014 Author Posted February 2, 2014 Hi Thorsten! Nice that you find the error! :smile: Thank you. Hopefully I've learned something from this issue and i will do a better troubleshooting next time. Here a preliminary version which provides more event pool memory for the STM32F4: http://www.ucapps.de/mios32/midibox_ng_v1_030_pre1.zip Your preliminary version is working. Event pool allocations decreased from 99% to 37%. Best regards Marxon
