unfortunately i have some two problems with my new STM32F4 core module.
I uploaded the actual bootloader 1.015 and Midibox NG 1.029 version.
This ports are wired J16, J8/9, J19, J15A and J15_S.
Problem 1:
The event Event Pool Allocation is 24480 of 24576 bytes (99%) exactly like
using the LPC1769 core. Shouldn't be there more bytes available :question:
Problem 2:
The LCD does not work (backlight and contrast are ok).
It is a 2x16 HD44780 display.
I have triple checked the wiring and soldering.
TK, your help is needed :)
Best regards
Marxon
Did you compile for the new target?
Edit: ok, I just saw that you can now download a binary version for STM32F4, and you skip compiling yourself. So, you are using that one?
Edited by ilmenator
OK, open MIOS, clear your terminal screen and send load the Bootloader 1.015 hex file - not the MIDIbox NG application.
-> What does the terminal say at the very top?
For exmaple, my STM32F4 core isn't hooked to and LCD or anything else and it says:
[386343.822] Initialize LCD #1
[386343.886] Failed - no response from LCD #1.1
[386343.886] Initialize LCD #2
[386343.950] Failed - no response from LCD #2.1
Also, I just compiled the MIDIbox NG application for the STM32F4 on my pc using the latest SVN source.
You can try it out: http://sneak-thief.com/MIDIboxNG/project.hex
It loads fine and gives me the appropriate message for my setup:
[387180.219] [MBNG_LCD] no response from CLCD #1.1
[387180.220] [MBNG_LCD] no response from CLCD #2.1
Edited by sneakthief
After uploading your .hex MIOS gives this output:
[78833.839] Init DHCP
[78834.846] SD Card connected:
[78835.015] [MBNG_FILE_C:317] WARNING: no CC number expected for EVENT_ENC due to type: Disabled
[78835.443] [MBNG_FILE_C] Event Pool Number of Items: 734
[78835.443] [MBNG_FILE_C] Event Pool Allocation: 24480 of 24576 bytes (99%)
[78835.450] [MBNG_FILE_L] DEFAULT.NGL hasn't been changed; reading labels from existing DEFAULT.BIN file.
[78835.451] [MBNG_FILE_L] 7 labels found in /DEFAULT.BIN file
[78835.456] [MBNG_FILE_S] loading snapshot #13 from /DEFAULT.NGS
Entering "system" into the terminal gives this:
[78917.869] Application: MIDIbox NG V1.029
[78917.870] MIDI Monitor: disabled
[78917.870] MIDI Monitor Filters: enabled
[78917.870] MIDI Monitor Tempo Display: disabled
[78917.870] Print AOUT Config: TODO
[78917.870] lcd_type: 0x00 - CLCD
[78917.870] lcd_num_x: 1
[78917.870] lcd_num_y: 1
[78917.870] lcd_width: 16
[78917.870] lcd_height: 2
[78917.870] Event Pool Number of Items: 734
[78917.871] Event Pool Allocation: 24480 of 24576 bytes (99%)
I see there's nothing about LCD's, like mine:
[389191.893] [MBNG_LCD] no response from CLCD #1.1
[389191.894] [MBNG_LCD] no response from CLCD #2.1
[389191.894] Init DHCP
[389196.915] SD Card not found
But what does it say when you ONLY load the bootloader, like I asked above?
Mine again:
[389537.459] Initialize LCD #1
[389537.523] Failed - no response from LCD #1.1
[389537.524] Initialize LCD #2
[389537.587] Failed - no response from LCD #2.1
[389537.588]
[389537.588] ====================
[389537.589] Bootloader 1.015
[389537.599] ====================
[389537.602]
[389537.613] Checking Bootloader...
[389537.633] No mismatches found.
[389537.635] The bootloader is up-to-date!
[389537.651] You can upload another application now!
[389537.673] Or type 'help' in MIOS Terminal for additional options!
[79878.592] Initialize LCD #1
[79878.649]
[79878.649] ====================
[79878.649] Bootloader 1.015
[79878.660] ====================
[79878.662]
[79878.674] Checking Bootloader...
[79878.751] No mismatches found.
[79878.754] The bootloader is up-to-date!
[79878.769] You can upload another application now!
[79878.791] Or type 'help' in MIOS Terminal for additional options!
So, we can see that it's "initialized".
I think this output below only shows the stored CLCD config and NOT the actual one because it says the same on mine when I type "system" in the MIDIbox NG application:
At this point, the only possibilities are:
1. Dead CLCD
- time to test another CLCD?
2. Something weird with the software and/or configuration
- das Heisst: keine Ahnung... TK! Wo bist du denn? :P
3. Bad wiring between the STM32F4, the 74HC595 and the CLCD. Did you try another 74HC595?
- time to post a picture of your wiring (both sides, high-res please)
1. LCD works with LPC core
2. Ehrlich TK, zu der Uhrzeit solltest du noch online sein ;)
3. Checked wiring 10 times. Also tried another 74hc595.
Edited by Marxon
Damn! Kick me in my ass!
I checked everything... Really everything?
No, i left out the resistor array which turns out to be a 10k ohm array.
:angry: :angry: :angry:
This might be the problem!
I am going to change it and post result in some minutes...
Hi Thorsten!
Nice that you find the error! :smile:
Thank you.
Hopefully I've learned something from this issue and i will do a better troubleshooting next time.
Here a preliminary version which provides more event pool memory for the STM32F4:
http://www.ucapps.de/mios32/midibox_ng_v1_030_pre1.zip
Your preliminary version is working.
Event pool allocations decreased from 99% to 37%.
Best regards
Marxon
