FantomXR Posted February 16, 2014 Posted February 16, 2014 (edited) Hey, I'm thinking of using this buttons in my next ucapps project: https://www.sparkfun.com/products/9277 From the schematic it seems, that they already designed for use in a matrix. But when I compare the schematic of the button pad with the one from the DIN module, it seems, that they did it the other way around. The button pads don't have a groundline, but the inputs of all buttons are connected. Is it possible to use the button-matrix of the NG anyway or do I have to connect each button separately? Can I use the "inverted" parameter in the NG for this application? Thanks, Chris Edited February 16, 2014 by FantomXR
TK. Posted February 18, 2014 Posted February 18, 2014 Hi Chris, what they call "GND1/2/3/4" are actually the selection lines, provided by a DOUT SR which has been assigned with sr_dout_sel1=<number> The other side of the switches will be connected to a single DIN input. Best Regards, Thorsten.
FantomXR Posted February 24, 2014 Author Posted February 24, 2014 Hey TK, thanks for the reply! Now I know how to use them... will be great. Best, Chris
novski Posted March 1, 2014 Posted March 1, 2014 I have this running. It works well! but be carefull if you layout your own board. The Library files contain several different versions and i chose the wrong one in my first Layout... br,novski
FantomXR Posted March 1, 2014 Author Posted March 1, 2014 Hey, I use the 2x2 boards from sparkfun without creating a layout for my own pcb.
