EsotericLabs Posted June 8, 2014 Report Posted June 8, 2014 Hello guys, Does someone in the EU have some spare connectors cables (Reichelt PS25/8G WS or BR) and a 7 pin DIN pcb connector for sale? the latter one is for the power connection of an MB6582. Thanks! Quote
Shuriken Posted June 8, 2014 Report Posted June 8, 2014 If only i had know, i ordered from Reichelt last week :sad: Quote
kristal= Posted June 8, 2014 Report Posted June 8, 2014 http://www.ebay.nl/itm/2-x-7-Pin-DIN-PCB-Sockets-Audio-066-/360720904383?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item53fca430bf Quote
kristal= Posted June 8, 2014 Report Posted June 8, 2014 (edited) For the PS25/8G replacement, check out: http://www.ebay.nl/itm/10pcs-2-54mm-KF2510-8P-Pin-Header-Right-Angle-Terminal-Housing-Connector-Kits-/121083673010?pt=LH_DefaultDomain_0&hash=item1c312639b2 Or search for a Molex KK seller in Europe, e.g: http://www.ebay.nl/itm/Molex-KK-6471-0-1-2-54mm-PCB-Connector-Housing-Header-Crimp-Pin-Various-/111121574501?pt=UK_BOI_Electrical_Components_Supplies_ET&var=&hash=item19df5caa65 Could fit, too: http://www.ebay.nl/itm/5pcs-2-54mm-20cm-Dupont-Cable-8P-8P-Connector-Female-to-Female-/370873985031?pt=LH_DefaultDomain_0&hash=item5659cfe807 http://www.ebay.nl/itm/1PCS-XH2-54-Wire-20cm-8-pins-Connector-two-leads-Head-/121046716300?pt=LH_DefaultDomain_0&hash=item1c2ef24f8c Edited June 8, 2014 by kristal= Quote
Shuriken Posted June 9, 2014 Report Posted June 9, 2014 (edited) I think i actually have the DIN connector for you if you still want it. Forgot i salvaged one more from a C64. Sorry my mistake, i only have a couple of c64 power switches and a C128 DIN connector. Edited June 9, 2014 by Shuriken Quote
freddy Posted June 9, 2014 Report Posted June 9, 2014 EsotericLabs, if you didn't go for the eBay way I do have both, the connector with no cable, however, but as individual components (pins, housing and straight PCB male part), no problem to crimp a cable for you if needed. Located in Slovakia, might you be interested? Cheers, freddy Quote
