Hello..
I am building a project based on the MBHP_CORE_STM32F4
I wanna add a 4.3" TFT LCD and the module i will use is this : http://www.4dsystems.com.au/product/4DLCD_FT843/
There is a 10 pin out from the screen.
Here is the datasheet : http://www.4dsystems.com.au/productpages/4DLCD-FT843/downloads/FT843-4.3-Display_datasheet_R_1_2.pdf
Here is the pin out :
PIN                SYMBOL
1  ------->        3.3V
2  ------->        SCK
3  ------->       MISO
4  ------->       MOSI
5  ------->        CS
6  ------->        INT
7  ------->        PD
8  ------->  AUDIO_SHDN ----> Audio shut down ( dont know if i need it )
9  ------->  AUDIO_OUT   ----> Audio Out ( dont know if i need it )
10 ------->     GND
Any help on how too connect the pin out on the STM32F4Discovery pin out??
This display won't work because:
- it isn't supported by MIOS32
- graphical LCDs are not supported by the MBSEQ V4 application
- the screen dimensions are not supported by the MBSEQ V4 application
- the 80x2 character row would be hard to read with this small size
-> bad choice
Thanks for your reply Thorsten
First of all STM32F4 can support those lcd's.. i 'm just asking the pinning :)
I'm making a clone of TR-808 and i wanna use your amazing Midibox Sequencer. I will not use the old MB808 seq... My design started from the begin and here is my concept :
1) TR-808 Voice Boards designed from the begin with SMD compoments wich means smaller and cheaper pcb. ( I have my own DIY SMD oven :D )
2) Midi Interface wich means you can have different Accent(Velocity) for each instrument from a digital sequencer like midibox.
3) More voices than the original TR-808. ( I ll add Guiro and maybe some extra snare drums and also i am planning too add some 909 voices.)
4) Cymbal / Hi Hat / Hand Clap / Maracas / Snare Drum alternative noise inputs from front panel with patchcables. Alternatives sounds will be : Original Pink/White noise from 808 circuit or a 909 circuit or any other noise source,even a microphone.
There will be many future adds that i am currently working on..
I want to use the midibox seqv4 but i wanna make a different version with GUI and real buttons. ( Midibox DR and MB seqv4 is not enough for me) I need to make a module that will help me make my dream come true and give some ideas so the midibox sequencer project go further.
Here some pictures from my work on TR-808 voiceboard cloning in Altium Designer.
Best Regards, Tilemachos.
Yes i figured it out.. I 'm under datasheet reading now.. I think will be not a problem to make an lcd driver and mios compatible..
Excuse me for my bad English if you guys see any mistakes!
:smile:)
EDIT :
What about using the J16 on MBHP_CORE_STM32 for wiring this lcd??
I will make drivers from the begin and i will make it mios32 compatible..
What you think it is possible??
Edited by Navicat
Already under construction :smile:)
Here is the schematics i started!
I just purshaced the an STM32F4 and the LCD from 4D Systems.. Can't wait to start.
Thanks for your attention and your answers everyone!
Edited by Navicat
