Here is a velocity control for each voice module of a TR-808. The concept is simple..
What i did is i took the accent circuit from the original schematics and i place a digipot that will control the velocity for every single voice separately.
A Digipot chain will be connected at J19 of the STM32F4 Core. Each Digipot is controlling the Velocity Value on each instrument. So let's see.
A Pin from Dout module sends a Trigger of +5 Volts. One Branch goes at the Trigger in of the Voice module.
The other branch is going into my circuit.
The digipot controls the velocity level from +5 volts to +15v. ( Even with 0 Velocity a 5v minimum trigger must go in voice module so we have sound.)
The result is a Trigger voltage  from +5v to +15v that goes into the Accent in of the voice module.
What we have here is a velocity control for every single note. :rolleyes:
I Need help on how to programm Digipots to do this job.
Here is the schematic Accent 5-15v.PDF
Regards Tilemachos
  • Like 1
