Navicat Posted February 16, 2015 Posted February 16, 2015 Here is a velocity control for each voice module of a TR-808. The concept is simple.. What i did is i took the accent circuit from the original schematics and i place a digipot that will control the velocity for every single voice separately. A Digipot chain will be connected at J19 of the STM32F4 Core. Each Digipot is controlling the Velocity Value on each instrument. So let's see. A Pin from Dout module sends a Trigger of +5 Volts. One Branch goes at the Trigger in of the Voice module. The other branch is going into my circuit. The digipot controls the velocity level from +5 volts to +15v. ( Even with 0 Velocity a 5v minimum trigger must go in voice module so we have sound.) The result is a Trigger voltage from +5v to +15v that goes into the Accent in of the voice module. What we have here is a velocity control for every single note. :rolleyes: I Need help on how to programm Digipots to do this job. Here is the schematic Accent 5-15v.PDF Regards Tilemachos 1
ganchan Posted February 20, 2015 Posted February 20, 2015 that's a good one, i really like something similar to cv the decay of the voices.
zephyrin Posted February 24, 2015 Posted February 24, 2015 Hi i have used the seb Drumbox for have velocity control for each instrument of my tr8060. http://burnit.co.uk/sdiy/index.php?page=drumbox I have connected the accent and trigger input on the same output pulse. Trigger input work fine with a pulse between 5v and 15 v so you don't need to send a spécific +5 Volts.
