Great session length! I always mess up after around 3 or 4 minutes or so, need to learn how to chill :-)
The SEQ V4 is awesome for this kind of stuff, keep it up!
Thanks guys... I have barely scratched the surface of the sequencer but big thanks to all here on the the board for support building it and TK... Also thanks to MIDILAB for the Pattern Rmix feature as this helps so much for transitioning into the next track... Still need to work on shortening the length of the tracks and transitions... Next set I make I am going to put everything in the Key of C and use the transpose function and take advantage of all the chords available instead of manually inputting chords via 3 note layers...
SETUP...
MIDIBOX SEQV4 - Master sequencer
MD MKII - slaved to SEQV4 patterns changed via midi not command
DARKENERGY MKI - slaved to SEQV4 via midi can be controlled via CV/gate but cant get the scaling dialed in well enough... arps mostly and leads...
ACIDLAB BASSLINE -  rx's midi clock
Moog Minitaur - basslines and does it well...
MKS-30 (PG200) - chord stabs and pads
JOMOX Mbase01 - kicks rx's program changes via SEQV4
Ensoniq DP/4 - fx config'd for 4x1 4 fx sends to A&H MixWizard... Porg change via SEQV4... Fx used Delay verb comp and misc
A&H MixWizrd 16:2 -  Great mixer as now I can use all 4 fx sends from the DP/4 send 3 always has a comp so I can use on the Mbase and Minitaur...
RNC 1773 Comp - Tame and round out the master mix...
All this in a roadcase... After 20 years this is what I have come up with and no longer use a computer or sit and arrange a track... Just walk up hit play and go to town always a good time with this rig and lots of hands on control...
Now I just need some gigs...
Edited by cosmosuave
